Wood splitting with a B3200
   / Wood splitting with a B3200 #11
I use a Super Split with 2 second cycle time.
No way I could get by with a slow tractor mount splitter.
   / Wood splitting with a B3200 #12
Another reason for a 3pt splitter. One less engine to maintain... You'll hear both side of this argument all day long.. I burn 3 cords a year for my cape size house. The Powerhorse is great unit as I stated in my earlier post...... Good luck
   / Wood splitting with a B3200 #13
I didn't see cost listed on my smsll phone screen... But the cost of putting remotes is probably highr than a 3pt pto pump. less flexible but will have 3x the flow and a larger fluid volume.
   / Wood splitting with a B3200 #14
Do you have a 4 way on the super split? I can quarter logs < 4 seconds with my tractor mounted split fire. It took a minimum 3 splits with the speed pro kinetic i took back to quarter a log Because the push blocks are so small on the kinetics you can not double stack the halves. The other thing i did not like with the super split style was the propensity of the splitter to propel large pieces of gnarly wood back at the operator at high speed. It was fast though super split definitely makes the best kinetic splitter. It was also a pain to lift 24"- 30" pieces onto the table. Log lift on the split fire fixed that problem
Dave
   / Wood splitting with a B3200 #15
It would be nice if someone made a 3PH kinetic log splitter.
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2016 INTERNATIONAL PROSTAR 113 T/A DAY CAB ROAD TR (A51243)
2016 INTERNATIONAL...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
John Deere 893 Corn Head (A50514)
John Deere 893...
