wood spliter power coupling
/ wood spliter power coupling #1
dlabrie
Campton, NH
Kubota B2910
I have a 15-20 yr old Mighty Murc wood splitter. It is hard to make out the model # it looks like 27 or 2?7. the serial # is B3301. There is a doughnut-like piece of hard rubber that goes between the power output of the 8hp engine and the hydro pump. It has disintegrated. This happened about 6 years ago and the dealer gave me one to put in. Well the dealer is long gone and I can't find anyone that knows what I am talking about.
First, does anyone know what this part is called.
Second, Where can I get one?
Thanks,
Thanks!
Now that you mentioned the name 'Lovejoy' I remember that is what the dealer called it. The item at Northerntool is exactly what I need.
When I measure what size I need, do I use the space I see now between the drivers or is that a compressed space? Is there anything I should know before I take the housing apart to replace the insert?
Thanks,
Thanks again.
</font><font color="blueclass=small">( Look at a Lovejoy coupling, in a hydraulics store. Maybe Northern Tool or Surplus Center.
http://www.lovejoy-inc.com/
Here are couplings at Northern Tool )</font>
I took the pump away from the engine. It looks like I should replace the entire coupling. The teeth on the drivers are all chipped or broken. I was able to loosen the set screw on the engine side, but I have twisted 3 allen wrenches trying to get the screw out of the pump side. I sprayed some Break Away on the set screw but it won't budge.
Should I try to drill it out?
Thanks.
/ wood spliter power coupling #5
I doubt if you'll be able to drill it out.....do you have a little grinder? If you do, (or a hacksaw, depending on how much room you have around the engine) cut a slot in the coupling and break it off, then replace the whole coupling. Or, just put a good gearpuller on the coupling and pull it off, then dress the shaft...........
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2022 EZ-GO ELITE...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
429858 (A61165)
429858 (A61165)
