WOOD RACK = Fun Project
/ WOOD RACK = Fun Project #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
Actually built the wood rack last year or this spring. It is a fun project that will keep you out of trouble for a day or 2. Can be used inside the house or outside. This 1 is fairly small only about 36"X32", holds 2 or 3 days wood. That sort of depends on how much you burn.
Good practice for new or novice welders, nothing tricky or hard to do. Only place you need to be careful is welding the nuts on for the adjustable legs. By the time you get that far, your welding should be pretty good.
Also shown are a couple of stoves built last year. They were detailed in some posts about a year ago.
/ WOOD RACK = Fun Project #2
Nice work. Looks good and functional.
/ WOOD RACK = Fun Project #3
That's a good use for a pile of old horseshoes.
Only issue I see is that under the weight of that wood, those little feet would sink into the ground, unless they're sitting on rock or something.
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
139 (A63291)
139 (A63291)
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2023 Case TV450B (A62177)
2023 Case TV450B...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
