Wood max 8m infeed problem
/ Wood max 8m infeed problem #22
I've never seen a CNC knife sharpener. All manual as far as I know of. No reason for CNC, you aren't machining anything. Basically, you jig the knives, spark the grinding wheel on the angled face, dial down a couple thou and remove material, rinse and repeat until the face and cut edge is uniform. One thing I do when I sharpen them is I take a DMT diamond whetstone and remove the backside burr that develops when grinding. Whey you remove the burr, you can shave with a sharpened knife. I've cut myself many times on sharpened knives. I tend to apply 2 layers of masking tape to the finished bevelled edge so I don't slice myself. Very, very sharp.
Not familiar with a Makita either.
I guess it’s not actually CNC, but it is automated. The guy I used had a unit that could sharpen about 6 blades at one time. It’s similar to this unit. There was one guy in town that had similar unit. He has since moved out of state.
or a Chinese copy,
/ Wood max 8m infeed problem #23
Then the included angle on the knives is wrong. Should be between 26 and 28 degrees. I must ask however, what did you set the knife to anvil clearance at? Hint, use an old credit card to set the clearance.
How you set the knives in a commercial chipper, old credit card.
I don't own a chipper, I roast my stuff, but I sure as hell sharpen a boatload of chipper knives.
Thank you for clarifying you don’t actually own one and don’t know how these work for setting the blades.
/ Wood max 8m infeed problem #24
Not exactly. I DID own one for years and sold it for what I paid for it actually. I find it much easier and less time consuming to roast the wood. Besides, I'm a pyro.
How I got into sharpening knives in the first place. No one around here did it so I inquired with tree companies about who sharpened their knives and in as much as I own the machine tools (ie: large surface grinder, it was simply a matter of obtaining a tilt table for the grinder bed. Nothing more than one piece of additional tooling.
The table allows me to jig and sharpen the knives at any angle I want to set it at. I have from sharpening 100's of chipper knives that the included angle across all makes is between 26 and 28 degrees. Chipmore, Bandit, CMC or whatever.
I know exactly from experience and precision angular measurement with the included angle should be. Most likely something you don't have the capability to determine in the first place.
I also know from my personal experience and from talking to various tree companies I sharpen knives for, what the clearance between the knife and the anvil should be. All the operators I talked to use an old credit card to set the knife to anvil clearance.
I'd say YOU are the one who don't know, not me.
/ Wood max 8m infeed problem #26
Reading several replies to others' ideas it sounds like this is mainly a problem with green viny schtuffe, right?
If so: I gave up doing any viny material in my 8M. It wraps as you've noticed and has a tendency to clog the outlet.
I remind myself that the 8M is a wood chipper, not a do-it-all trash grinder, and pile the viny crap for a quick burn.
As for bark joining the tangle: I have some problems with tulip poplar and eastern red cedar. I just have to be very watchful.
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
1992 Rammax Trench roller and Extra Set of Drums (A62613)
1992 Rammax Trench...
JOHN DEERE 4760 TRACTOR (A64280)
JOHN DEERE 4760...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Odyssey Pontoon (A62613)
Odyssey Pontoon...
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
