Wood max 8m infeed problem
/ Wood max 8m infeed problem #22
I've never seen a CNC knife sharpener. All manual as far as I know of. No reason for CNC, you aren't machining anything. Basically, you jig the knives, spark the grinding wheel on the angled face, dial down a couple thou and remove material, rinse and repeat until the face and cut edge is uniform. One thing I do when I sharpen them is I take a DMT diamond whetstone and remove the backside burr that develops when grinding. Whey you remove the burr, you can shave with a sharpened knife. I've cut myself many times on sharpened knives. I tend to apply 2 layers of masking tape to the finished bevelled edge so I don't slice myself. Very, very sharp.
Not familiar with a Makita either.
I guess it’s not actually CNC, but it is automated. The guy I used had a unit that could sharpen about 6 blades at one time. It’s similar to this unit. There was one guy in town that had similar unit. He has since moved out of state.
or a Chinese copy,
/ Wood max 8m infeed problem #23
Then the included angle on the knives is wrong. Should be between 26 and 28 degrees. I must ask however, what did you set the knife to anvil clearance at? Hint, use an old credit card to set the clearance.
How you set the knives in a commercial chipper, old credit card.
I don't own a chipper, I roast my stuff, but I sure as hell sharpen a boatload of chipper knives.
Thank you for clarifying you don’t actually own one and don’t know how these work for setting the blades.
/ Wood max 8m infeed problem #24
Not exactly. I DID own one for years and sold it for what I paid for it actually. I find it much easier and less time consuming to roast the wood. Besides, I'm a pyro.
How I got into sharpening knives in the first place. No one around here did it so I inquired with tree companies about who sharpened their knives and in as much as I own the machine tools (ie: large surface grinder, it was simply a matter of obtaining a tilt table for the grinder bed. Nothing more than one piece of additional tooling.
The table allows me to jig and sharpen the knives at any angle I want to set it at. I have from sharpening 100's of chipper knives that the included angle across all makes is between 26 and 28 degrees. Chipmore, Bandit, CMC or whatever.
I know exactly from experience and precision angular measurement with the included angle should be. Most likely something you don't have the capability to determine in the first place.
I also know from my personal experience and from talking to various tree companies I sharpen knives for, what the clearance between the knife and the anvil should be. All the operators I talked to use an old credit card to set the knife to anvil clearance.
I'd say YOU are the one who don't know, not me.
/ Wood max 8m infeed problem #26
Reading several replies to others' ideas it sounds like this is mainly a problem with green viny schtuffe, right?
If so: I gave up doing any viny material in my 8M. It wraps as you've noticed and has a tendency to clog the outlet.
I remind myself that the 8M is a wood chipper, not a do-it-all trash grinder, and pile the viny crap for a quick burn.
As for bark joining the tangle: I have some problems with tulip poplar and eastern red cedar. I just have to be very watchful.
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2022 EZ-GO ELITE...
