Wood chipper conversion
/ Wood chipper conversion #1
chip3
I own a Danuser D18P woodchipper (PTO driven) and no longer have the tractor. I would like to convert it to run with an engine. Would a 20HP gas engine have enough power? The manual for the D18P recommends PTO rating between 20 and 45 HP.
/ Wood chipper conversion #2
20060613
I don't know that chipper but a few rules of thumb:
1- The more horses the better! Chippers love power. I have a Woods 5000 PTO and it can pretty easily bog down my Kubota BX-2200.
2- I'd contact Danuser via the web or otherwise to see how such a conversion will work.
You are going to miss that tractor when you need to move it. Sure you don't want to consider another cheap tractor to run it? You can probably buy an old farm tractor for not that much more than what you will spend on a large engine refit.
Jim
Thanks for your advice. I'll contact Danuser even if they stopped making chippers, they should be able to give me the information. You may be right about the tractor. It's very convenient but I find mine is just too expensive (lots of repairs- JD 1050)
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
Rotomec Auger (A64127)
