3-Point Hitch wont stay up
/ wont stay up #1
Licking
farm pro 2420
I own a farm pro 2420 and I am having a problem with the 3 point hitch when the implment is on a 2 bottom plow the hitch raises but wont stay up And Iam new to this so any information would sure help because Iam sure I dont know what the problem is because the hitch was wowrking just fine a few weeks ago but the raise and lower bar broke and I had to put in a new hitch pin is the little hole buy the seat but made no adjustments to the bar itself so thank you for any information you can feed me,
Steve.
also the engine is a ty290 if that helps.
/ wont stay up #2
Most common reason is bypass. There's an O-ring and a wiper or two inside the lift box. Problem with the design on that series tractor is there's an ineffective mechanical cylinder stop. If the rear arms are raised to high for any reason, the ram can come out of the cylinder far enough to expose the O-ring and wiper(s). When the arms are lowered, the seal and wipers are damaged as they're pulled back inside the cylinder. Not a terribly difficult or expensive repair, just messy.
That said, you should also check closely to rule out a leak in the valve that the lift lever is attached to.
//greg//
/ wont stay up #3
/ wont stay up
I sounds like a bad O-ring on the 3-point piston, we have a rebuild kit for it.You will have to remove the 3-point piston to replace the O-rings, it's not a hard job.If you need some help with it just give us a call 979-865-4002
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Thanks tommy I have the kit it came with the tractor I just dont know how to remove the 3 point piston do I need to take the back off or the whole upper casing of the lift any help will do
thanks steve.
/ wont stay up #5
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2008 JACK COUNTY 130 BBL VACUUM  TRAILER (A60736)
2008 JACK COUNTY...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
