won't start
/ won't start #1
colt357
Charlotte, Tennessee
New Holland, tc29d
I ran out diesel, I bled the system and the engine turns over, the local new Holland store said to spray a little starter fuel in it. After that when turning the starter it has a thud in the sound an turns over. The fuel gauge will show full, but when it is empty it shows 3/4 full. I need help with both things....
/ won't start
Corfed, Yes the sound appears to be from the block.... it did this after the starter spray was added.
/ won't start #4
I'm shooting in the dark here friend but starting fluid and an engine with a glow plug is asking for dangerous detonation and you might have damaged something in the top end.
/ won't start #5
Or possibly the bottom end...............may have blown a piston out. I can't believe a dealer would tell him to put ether to an engine with glow plugs............without instructions on how to bypass the glow plug circuit.
A compression test needs done right away..................before anything else is done.
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2007 KENWORTH W900 (A67714)
2007 KENWORTH W900...
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
2021 MK Martin...
