won't run after new manifold
   / won't run after new manifold #1
Terry N
Fosston, MN
John Deere 60
I just installed a new manifold in my 1952 John Deere 60. It now will only start and run on full choke and runs very fast no matter where the speed lever is placed. Any ideas re: how to correct?
   / won't run after new manifold #2
Sounds like you have a big vacuum leak. Was the new manifold actually new or used? Something must not be sealing properly.
   / won't run after new manifold #3
With the engine running, spray carb cleaner around the manifold.
If the RPMs pick up, you've located your air leak.
Carb choke & throttle pivots/bushings can be leak points, too.
   / won't run after new manifold #4
I agree
   / won't run after new manifold #6
Did you put new gaskets on. I always check for warpage of the surfaces and use Permatex ultra copper on each side of the gasket before putting it on.
The carb cleaner trick works real good.
Also did you torque the bolts to the correct specs?
2004 Wabash National 28ft Dry Van Trailer (A51692)
2004 Wabash...
Polaris ATV (A50324)
2013 John Deere 824K Wheel Loader (A53473)
2013 John Deere...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
Adams 8 Ton Weigh Hopper (A53473)
Adams 8 Ton Weigh...
