won't run after new manifold
   / won't run after new manifold #1
Terry N
Fosston, MN
John Deere 60
I just installed a new manifold in my 1952 John Deere 60. It now will only start and run on full choke and runs very fast no matter where the speed lever is placed. Any ideas re: how to correct?
   / won't run after new manifold #2
Sounds like you have a big vacuum leak. Was the new manifold actually new or used? Something must not be sealing properly.
   / won't run after new manifold #3
With the engine running, spray carb cleaner around the manifold.
If the RPMs pick up, you've located your air leak.
Carb choke & throttle pivots/bushings can be leak points, too.
   / won't run after new manifold #4
I agree
   / won't run after new manifold #6
Did you put new gaskets on. I always check for warpage of the surfaces and use Permatex ultra copper on each side of the gasket before putting it on.
The carb cleaner trick works real good.
Also did you torque the bolts to the correct specs?
2005 Big Tex Trailer Trailer (A52377)
2005 Big Tex...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2016 Freightliner M2 106 Medium Duty 26FT Box Truck (A51692)
2016 Freightliner...
Unused 2025 Electric Cart (A51694)
Unused 2025...
Hyster H225E (A47384)
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
