won't run after new manifold
   / won't run after new manifold #1
Terry N
Fosston, MN
John Deere 60
I just installed a new manifold in my 1952 John Deere 60. It now will only start and run on full choke and runs very fast no matter where the speed lever is placed. Any ideas re: how to correct?
   / won't run after new manifold #2
Sounds like you have a big vacuum leak. Was the new manifold actually new or used? Something must not be sealing properly.
   / won't run after new manifold #3
With the engine running, spray carb cleaner around the manifold.
If the RPMs pick up, you've located your air leak.
Carb choke & throttle pivots/bushings can be leak points, too.
   / won't run after new manifold #4
I agree
   / won't run after new manifold #6
Did you put new gaskets on. I always check for warpage of the surfaces and use Permatex ultra copper on each side of the gasket before putting it on.
The carb cleaner trick works real good.
Also did you torque the bolts to the correct specs?
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
2019 Chevrolet Express (A50123)
2019 Chevrolet...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2012 Ford Crown Victoria Sedan (A51694)
2012 Ford Crown...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2019 Nissan Frontier Pickup Truck (A51692)
2019 Nissan...
