Wont move
/ Wont move #1
Dmg2076
Yanmar FX24D
Needing advice. I have a Fx24d and last evening i was pulling a small shed across the drive way and Iit just stopped moving. Shifted range selector down to 1 and it worked fine. Retried 2 again after unhooking and it worked as it should. Hooked back to shed and moved a few feet in 1 and then lost everything. Tractor will not move in any range or gear. Any help would be greatly appreciate. Thank you
/ Wont move #2
Try putting it in 4 wheel drive and see if front wheels will pull. Welcome to the forum. :welcome:
/ Wont move #3
Does PTO still work? Will it move with differential lock engaged? Check for broken power shift relief valve spring in top of transmission.
/ Wont move
Was in 4 wheel at time. Took it out and tried and also put back in 4 wheel. Still nothing
/ Wont move
It spins when engaged and stops when clutch is depressed. Didn’t hook anything up to see how much power is at pto thought
/ Wont move
Thank you Winston. You are the reason I joined. I say in other post your knowledge on these tractors and I was hoping I could get some help. Thank you
/ Wont move #7
I suppose you have tried moving the range shifter to different positions? I believe I would also try putting a bit of a bind on the pto also. If the pto does have power then that would eliminate the clutch as a possibility. Also try Norms suggestion of engaging the differential lock.
/ Wont move
Tried diff lock. Nothing. Will hook up pto when i get it home. Also on the range selector it should be 1-n-2-n-3. But it seems like it is only hitting 4 detents. If that makes since
/ Wont move #9
Would think yours would look like this. Should have 4 range shift speeds. Also, if you have the grandma lever (the one to the right in picture from the range handle) make sure it has not moved. 100_6507.jpg
/ Wont move
No grandma lever.
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2013 John Deere 7200 R Tractor (A66285)
2013 John Deere...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
John Deere 34" Mini Excavator Bucket (A64126)
John Deere 34"...
