Wish that had not happened!
/ Wish that had not happened! #21
bailing wire, is in the top 5 items to have on tractor at all times.
run a little bit of bailing wire through the stablizer pieces, doesn't not have to be much, but will help keep things from "un-spinning" and falling apart, and dropping some place in the last few acres you did something (never to be found again)
top link and side link turnbuckles do same thing. so they do not come loose (unspin) and fall off some place never to be found again.
other words, it has happened enough time over the years. that time it takes to deal with bailing wire, vs trying to walk around and find something, and then eventually going buy a replacement. cheap bailing wire = nice safety measure.
Hmmm, good idea on the bailing wire! I like good cheap/easy fixes that work! :thumbsup:
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
