Wish that had not happened!
   / Wish that had not happened! #21
bailing wire, is in the top 5 items to have on tractor at all times.
run a little bit of bailing wire through the stablizer pieces, doesn't not have to be much, but will help keep things from "un-spinning" and falling apart, and dropping some place in the last few acres you did something (never to be found again)
top link and side link turnbuckles do same thing. so they do not come loose (unspin) and fall off some place never to be found again.
other words, it has happened enough time over the years. that time it takes to deal with bailing wire, vs trying to walk around and find something, and then eventually going buy a replacement. cheap bailing wire = nice safety measure.
Hmmm, good idea on the bailing wire! I like good cheap/easy fixes that work! :thumbsup:
   / Wish that had not happened! #24
Had I seen this thread earlier, I could have used my "mind bend" technique for ya.:)
Where is Uri Geller when you need him!:D
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
JD ENGINE (A60432)
JD ENGINE (A60432)
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
TANK MANIFOLD (A58214)
