Wiring
/ Wiring #1
bigbill61
240 Massey Ferguson
Wiring 6volt to 12volt
I have a 1965 FORD 2000 that is a 6 volt positive ground. I would like to change to a 12volt one wire alternator. Can I make the tractor into a 12 volt negative ground without changing all of the wiring. I know I can use a 6 volt starter, but what about positive and negative grounds? Points,condenser and coil? By the way it is a gas motor as You could tell by points, condenser ,coil. Thanks in advance
/ Wiring #2
It seems that everything on that tractor would be 6 volt positive ground.
/ Wiring
Yes it is. Do You know what it would take to change it over?
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
5' Bush Hog (A62613)
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
