Wiring
   / Wiring #1
bigbill61
240 Massey Ferguson
Wiring 6volt to 12volt
I have a 1965 FORD 2000 that is a 6 volt positive ground. I would like to change to a 12volt one wire alternator. Can I make the tractor into a 12 volt negative ground without changing all of the wiring. I know I can use a 6 volt starter, but what about positive and negative grounds? Points,condenser and coil? By the way it is a gas motor as You could tell by points, condenser ,coil. Thanks in advance
   / Wiring #2
It seems that everything on that tractor would be 6 volt positive ground.
   / Wiring
Yes it is. Do You know what it would take to change it over?
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
Pickup Truck (A59230)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
*Selling at Royal Auction Zephyrhills, FL Location* Year: 2005 Make: Mitsubishi Fuso Model: FE84D (A59230)
*Selling at Royal...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
