Wiring saw for 240V
   / Wiring saw for 240V #12
Why the 'want' for 240V over 120V ?
The largest motor you can run on a 120 volt 15 amp circuit is about 1.5 horse power if everything were 100% efficient. They are not. Practically you can get about 1.25 hp. To get more you either go to a higher current on higher voltage or a more sophiscated motor (not a lot of gain here). It's cheaper to raise the voltage.
I know you see vacuum cleaners with 5hp running at 120 volt 15 amp circuit. The simple answer is they are lying.
   / Wiring saw for 240V #13
Will the saw arbor be able to handle the extra power and torque. If so this sounds like a good idea. I may convert my saw.
I would not hesitate one bit to go higher HP.
Notice the bore holes in saw blades. All the 8 & 10" blades are the same size and it is only 12" and up that go larger bore (shaft).
The sharpness of your blade will be the biggest factor in contributing strain on the shaft.
Just make shure your bearings are good and don't worry.
   / Wiring saw for 240V #14
Sounds good. It is worth the risk anyway. Where is a good place to get a motor.
It uses pulleys and three short belts - 8" or so - to transfer the power. I will have to resolve the new pulley too.
But first I think I will rewire the original motor to 240V to see if it makes a difference, the label says it is rated for it.
   / Wiring saw for 240V #16
That will probably be quite satisfactory.:)
   / Wiring saw for 240V #17
Willl, Think of voltage as pressure (psi) and amperage or current as flow (i.e. gallons per minute). The higher the voltage (pressure) the more amperage (GPM) will flow thru a given size wire (pipe). Doubling the voltage doubles (or nearly so) the power (ability to do work) in the same sized circuit. Kind of like3 gpm from a pressure washer vs the same 3 gpm from a garden hose.
Notice the wire size of the powerline going down your street as compared to the wire size feeding your house. A small wire (at very high voltage) can power many houses that need bigger wires ( at lower voltage) to carry the small portion of the current needed by your house. MikeD74T
   / Wiring saw for 240V #18
Mike, thanks for the lesson. :laughing::laughing:
But I didn't mean in general, meant just pertaining to a table saw. :thumbsup:
   / Wiring saw for 240V #20
Czech, your milage may vary, but normally for me, my HD has a much better electrical selection than Lowes, until you get to 220V 20A plugs, of which my HD carries Zero 0 or NONE. However, my Lowes carries a couple of versions.
They look like the 110 but the blade spacing is different enough to require the correct plug and socket.
They are about $5 each at my Lowes.
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Towable Sign Board (A55851)
Towable Sign Board...
30006 (A53424)
30006 (A53424)
Metal Shelving (A47477)
Metal Shelving...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
