Wires from the top rear of cab ?
   / Wires from the top rear of cab ? #1
Mercer1
Kubota B2650
Just purchased a 2021 Kioti DK4210se Cab and have wires with plugs coming out from frame at the top rear of the cab. Anyone know what they are for ? and are they connected to any power supply?
   / Wires from the top rear of cab ? #2
Possibly for rear work lights
   / Wires from the top rear of cab ? #3
Work lights, I betcha. Front, rear, side, wherever you want to string wires to, but they got them past all the windows for you. Put a voltmeter on them and see if they go live whenever you turn the headlights on.
   / Wires from the top rear of cab ? #4
Work lights sounds reasonable. But I'd be surprised if they were wired into the standard headlight switch. There's probably either another switch already present, or it's part of the option package for the work lights that it comes with an additional rocker switch somewhere on the dash or other cluster.
   / Wires from the top rear of cab ? #5
My dk45 came with front and rear work lamps, each switched separately. Is there a empty spot next to the switch for the front cab lights?
   / Wires from the top rear of cab ? #6
Pre wired for rear wiper kit.
Here is a picture. Im thinking its for a beacon light because the rear lights are already wired and there is no power to these wires. Maybe need a switch and relay to connect to fuse box.
   / Wires from the top rear of cab ? #9
I've got the same on my NX5510 (2016). I could look at the service manual, but going through schematics unless I really have to isn't something I'm inclined to do:cautious:
Hunch of it being for a beacon is probably the right call.
TANK MANIFOLD (A58214)
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
20704 (A55853)
20704 (A55853)
