WINTERIZING BUSHHOG
/ WINTERIZING BUSHHOG #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
My 6 foot RC has slip clutch and will be enjoying the outdoor weather over the winter. To prevent slipclutch from rusting frozen over the winter, would it be helpful to loosen SC bolts a lot and spray plates with WD40 or something preventatively??
/ WINTERIZING BUSHHOG #2
I havent had any luck with WD 40 preventing rust in a dry environment much less outside. I dont know if I would put any kind of oil base on the slip clutch. Loosening off the tension might not be a bad idea. As long as they dont seize together a little rust wont hurt it, you will peel that off when it slips when readjusting it next spring. OF course that is just my opinion
/ WINTERIZING BUSHHOG #3
I have kept my bush hog outside for years but I keep a tarp over it. Before I drop it I scalp the area where I am going to drop it and spray it with some household insecticide I have on hand - don't know if that helps I just want to discourage critters or spiders and such from taking up residence - then I drop and cover it and in the spring I service it and all has been well for years.
Sounds like Good advice. Thanks
/ WINTERIZING BUSHHOG #5
Why not just take the clutch off and put it in the garage or basement? As for that it may be a good idea just to take off the whole pto shaft and clutch and store out of the weather then cover the BH itself with a tarp.
Chris
/ WINTERIZING BUSHHOG #6
One thing of make sure of is that water cannot accumulate in the blade holder/stump jumper. I put a plastic bucket over the driveshaft and tarp the whole thing. I too use fluid film to coat things that might rust.
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
