Sprayer Winterize Your Sprayer
/ Winterize Your Sprayer #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
This is a reminder to all you Northerners. Don't forget to run some sort of antifreeze through your sprayer pump, tips, and wand before winter. It will save you parts and aggravation next spring. I use RV antifreeze, but I've heard of several other options.
/ Winterize Your Sprayer #2
Thats good advice for everyone. Even though we don't get as cold ... don't forget the pressure washer ..
/ Winterize Your Sprayer #3
I just drained my sprayer yesterday. Never thought of running antifreeze in it.
thanks for the tip.
/ Winterize Your Sprayer #4
if you guys changed your radiator coolant, this will work as well- just save the old stuff and use that. best way to save the old coolant.
/ Winterize Your Sprayer #5
Yep, drained and flushed, blew out lines with air, removed and cleaned the filters and tips. Never have use any kind of "anti-freeze" in my 3pt sprayer. Parked the outfit in the shed ready for action next spring. Neighbors 500 gal spray rig gets the RV anti-freeze treatment in pump and lines.
/ Winterize Your Sprayer #6
I never used the RV stuff just windshield washer antifreeze.
/ Winterize Your Sprayer #7
Most of the farmers use windshield washer so they can just spray it on the
ground in the spring. Thanks for the reminder. I need to treat my power
washer.
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
2012 LS G3038H (A64911)
2012 LS G3038H...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
