Winches and power drain
   / Winches and power drain #21
Yes there are cheap winches that dont free spool, But I dont recall or heard of a ATV winch that dont free spool.
Friend of mine has a cheap Chinese winch that doesn't. Can't remember labeled name.
   / Winches and power drain #22
Thing is, many of those cheapo winches make their way to ATV's by the owner trying to save $...
SR
   / Winches and power drain #23
I have a 3500# winch on my ATV (a cheapo Harbor Freight Badlands winch). Per the owner's manual, it draw 20 amps when running with no load, 81 Amps @ 1000# load, 232 amps @ 3500# load. So it's no surprise that a bit of winching will easily drain a typical ATV battery in short order.
   / Winches and power drain #24
I have a 3500# winch on my ATV (a cheapo Harbor Freight Badlands winch). Per the owner's manual, it draw 20 amps with no load, 81 Amps @ 1000# load, 232 amps @ 3500# load. So it's no surprise that a bit of winching will easily drain a typical ATV battery in short order.
Good stuff right there!!!
That's why I suggested searching the winch and the ATV's electrical abilities. Real quick you realize that you can't winch very long regardless of winch brand or ATV brand. They are not equipped with a charging system that will support that.
The cheaper the winch the higher the amp draw under load. That's one of the reasons there's a price difference.
   / Winches and power drain #25
And also a lower duty cycle on cheap winches!
SR
   / Winches and power drain #26
   / Winches and power drain #27
I have a HF 12K Badland winch and a Warn 12K winch, they are night and day different!!!
SR
   / Winches and power drain #28
SR
Yep. I paid $1,300 for the Warn winch on my off road buggy. It rocks!!!! High cable speed. Minimal amp draw.
Also have a slightly cheaper, $1,100 Warn winch on my driver Jeep. It also rocks. Slightly slower cable speed. Minimal amp draw.
   / Winches and power drain #29
SR
Wow really I would've thought the Warn winch would be better then HF.
   / Winches and power drain #30
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2012 Dodge Grand Caravan SXT Van (A55853)
2012 Dodge Grand...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
