Winches and power drain
   / Winches and power drain #41
I am considering a Kubota RTV 500, with winch Kubota offers as an accessory. Does anyone have this RTV/ winch combo, and how it compares to the experiences and suggestion offered by those responding to this thread?
   / Winches and power drain #42
its no different for any machine. they are not design for continuous use, more of a get unstuck and let it cool down if its a hard pull situation. generally the only type that can be run continous are hydraulic based winches.
   / Winches and power drain #43
That an a PTO winch.
+1. I have the Kubota side by side with the Kubota branded (Superwinch) winch and the OEM jar is just marginally adequate for one good pull and it's done and don't shut it off because you won't have enough juice to start it back up. I ditched the OEM flloded cell for a Hawker Oddesy gel cell. It's better but the alternator is the limiting factor now.
   / Winches and power drain #44
You are suppose to have the engine running while doing most anything, with your winch.
   / Winches and power drain #45
   / Winches and power drain #48
Sorry that I missed your line about leaving it running.
My issue with my side by side is it's an EFI motor and the ECU requires a minimum of 9 volts to remain operational so If I did run the battery flat, the unit would shut off anyway. Too heavy to push anywhere...:D
Well I must say that this thread has produced a wealth of info -- thank you all. The bottom line I draw from all of this is that a winch on an ATV is of pretty limited value.
   / Winches and power drain #50
It beats walking. Just need patience. :)
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2013 John Deere 824K Wheel Loader (A57024)
2013 John Deere...
