Winches and power drain
/ Winches and power drain #41
I am considering a Kubota RTV 500, with winch Kubota offers as an accessory. Does anyone have this RTV/ winch combo, and how it compares to the experiences and suggestion offered by those responding to this thread?
/ Winches and power drain #42
its no different for any machine. they are not design for continuous use, more of a get unstuck and let it cool down if its a hard pull situation. generally the only type that can be run continous are hydraulic based winches.
/ Winches and power drain #43
That an a PTO winch.
+1. I have the Kubota side by side with the Kubota branded (Superwinch) winch and the OEM jar is just marginally adequate for one good pull and it's done and don't shut it off because you won't have enough juice to start it back up. I ditched the OEM flloded cell for a Hawker Oddesy gel cell. It's better but the alternator is the limiting factor now.
/ Winches and power drain #44
You are suppose to have the engine running while doing most anything, with your winch.
/ Winches and power drain #45
/ Winches and power drain #48
Sorry that I missed your line about leaving it running.
My issue with my side by side is it's an EFI motor and the ECU requires a minimum of 9 volts to remain operational so If I did run the battery flat, the unit would shut off anyway. Too heavy to push anywhere...:D
Well I must say that this thread has produced a wealth of info -- thank you all. The bottom line I draw from all of this is that a winch on an ATV is of pretty limited value.
/ Winches and power drain #50
It beats walking. Just need patience. :)
/ Winches and power drain #51
I'll have to differ with that assessment. If you keep your engine running and know they are your batteries nemeses, they are still great asset to have along. .
/ Winches and power drain #52
How does DC winches compare with other things that run on battery that has lot of amp draw like power dump trailers.........
/ Winches and power drain #53
Power dump trailers use a linear actuator to dump (usually or a 12 volt powered motor / hydraulic pump and neither pull the amps a winch does at full pull.
/ Winches and power drain #54
If you run the battery so flat from winching that you cant even get enough juice to click the starter, then theres two things going on here, 1> you dont have a high amp battery, 2> your doing to much winching. One of the downfalls of automatic transmissions is they cant roll down hill to start.
/ Winches and power drain #55
Really, news to me...lol
I thought you just ran the battery down and pushed the ATV home...
That was back in the old days now you just call one of your buddy's on a cell phone at 2 am.
/ Winches and power drain #57
Yeaaa, there's no free lunch, electric winches are power hogs, that's why they invented the pto winch!
NO ATV alternator can keep up with a electric winch, not even a small electric winch... There isn't even enough room inside an ATV's motor/side covers, to put a big enough alternator in, that would even come close to keeping up...
SR
I've been getting free lunches for a month now at work...........
/ Winches and power drain #58
I'd be more apt to believe you have had too many beers, before you typed that...
SR
No beer just a natural amp high, I get those once in a while. Would you believe my tractor DC winch runs on solar power............
/ Winches and power drain #59
:thumbsup:
BRINKMANN SMOKER (A63745)
BRINKMANN SMOKER...
Kubota KX080-5 Midi Excavator w/ Hydraulic Thumb (A64047)
Kubota KX080-5...
2012 MACK GRANITE-GU713 (INOPERABLE) (A63569)
2012 MACK...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
30" X 12' STAINLESS STEEL BUFFET BAR/WARMING TABLE (A63745)
30" X 12'...
203201 (A60429)
203201 (A60429)
