Winch Modifications
/ Winch Modifications #111
I don't understand the C port. I am guessing that you are referring to the PB port. You might get away with that for a while, but you risk destroying the valve. The return port gallery in the valve usually can't take more than 500 psi.
Have you done a complete test on the setup? Have you pulled or released a heavy load.
I think I understand why nothing bad has happened. In the reverse mode you are extending the cable with min pressure. Unlike a cyl at it's pressure limits, the hyd motor in reverse is just unwinding the cable.
In the reverse mode from the front valve, the relief on the rear valve only sees the fluid on it's way out of the valve, which is the IN port.
I would still recommend the solenoid valve for winch operation. You can move the fwd and rev control wherever you want.
If you did not install the PB sleeve to block the return galleries, the OUT port is the same as the PB port.
I could plump the flow from the PTO circuit if damaging the new valve is a problem I looked at the specs and they say the maximum pressure at the tank (T) port is 500 PSI. I have that blocked off. There is a plug for power beyond operation. The note says install this plug for power beyond operation. This appears to block on the tank (T) port from the C port and allow high pressure on the output of C.
Our messages crossed. The C port on this valve becomes the PB port when you put the plug in the C port. See my previous post. The PB port should take full pressure?
I have not pulled a heavy load yet.
/ Winch Modifications #114
I am not trying to bash your setup, but I have never seen or heard of a setup like yours, and operate correctly. I am not so positive that it will work. I hope it does work for you.
Oops! I noticed just now that the T port is being used instead of C. I am going to call Surplus Center tomorrow and get a second opinion. After our discussions I now understand a lot more about this valve. I did not understand the plug symbol. You are right in that tank pressure should not exceed 500 PSI. I did discuss this with the tech support guy at surplus center.
J_J and Moss, thanks for all of the input, comments, etc. I think you just saved me from a bad error. J_J, I know you are trying to be helpful and I appreciate it. I have a lot to learn about hydraulics.
Oh, if I used the PTO would the extra flow damage the winch motor?
I just found a way to copy the valve connections drawing. If you follow the C port in from the left, then down, then left - You will see a square box. That square box is the plug (I think). I hope this helps.
/ Winch Modifications #117
What is the GPM capacity of the winch motor? GPM will determine speed of the hyd motor. That valve will handle 8 GPM's, should you continue to use it.
If you are going to use that valve, I would set the front valve to send fluid back to the rear valve using correct ports. I would only use the lever on the rear valve for the winch control. The out flow from the winch would exit the valve via the tank port. That flow would then go through the front valve and then to tank.
I don't know the GPM of the winch motor. It is at least 4GPM. I would need to call PT for that.
I called Surplus Center and he agreed with J_J. I then called Prince and talked to Dave. After a 10 minute discussion we agreed on the following setup.
1. Put the plug in the C port to enable power beyond. This separates the T from the C port.
2. Tie one line from the quick attach hydraulics to the P port and one to the C.
3. Set the relief valve in the new valve to max.
4. On the T port: Either vent it or return it to the tank. With the relief valve set at max, the valve in the Power Trac aux hydraulics will provide the relief function. However if there were some leakage to the T port, the pressure could build up and damage the valve.
I hope this is clear. My thanks for all of the comments. I go now to implement this.
/ Winch Modifications #119
Bob,
Did they say it was alright to pass fluid into the PB port?
I am still not understanding this.
Any fluid used by the work ports will flow out the tank/Out port. You can not just vent it. Tank port should go to tank/reservoir.
The PB port is used to pass fluid downstream.
Your rear valve will work as a winch valve if you do not use the QA valve to reverse the flow through the rear valve.
JMHO
Edit on this: The tank port is putting out a lot of oil through the vent I drilled in the cap. After talking with the Prince guy again, he stated that you can expect a lot of leakage flow. I will now have to return the T port to the tank. Well, live and learn. I have to get some parts and a hose made up.
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
