Winch, log trailer with grapple or both ??
   / Winch, log trailer with grapple or both ?? #21
Good question. You can load a trailer with your tractor. Is the unloading the reason you would want the trailer mounted grapple? Buy a dump trailer. Save yourself some money.
   / Winch, log trailer with grapple or both ?? #22
the grapple trailer is basically making your tractor a log forwarder. You would use a 3 pt skidding winch to get the log from the stump to a landing in your woods. You would use the grapple trailer to get the logs form your landing or many landings to the road were a log truck would pick them up or if you had to get the logs down a public highway. Now if it's a small parcel of land it would be easier to just skid the logs from the stump to the road.
A grapple trailer would be good for keeping logs out of the dirt if your not working when snow is on the ground. It would also be good for fire wood logs , because you can hold the log at waiste hieght with the grapple and block the wood to be split with out bending over to cut on the ground, and running your saw in the dirt
   / Winch, log trailer with grapple or both ?? #23
A grapple on the pallet forks works great for loading and unloading logs, it also works perfectly to hold firewood logs at any height you need and is MUCH cheaper than a grapple on a trailer.
Me, I much prefer to hold them over my wagon,
so I don't have to lift them later when splitting.
SR
   / Winch, log trailer with grapple or both ?? #25
You don't have to spend a fortune to have a good log hauler, an old hay wagon will do,
Even an old "running gear" makes a good log hauler, it doesn't even need a hay wagon body on it!
IF you have LOTS of logs to move, pull doubles!
Anyway, the point is, you just don't have to spend a bundle to move logs!
SR
   / Winch, log trailer with grapple or both ?? #26
Your picture illustrates how tricky it would be to try and pick off just one log using just forks without a grapple.
Even trickier if you use bolster* stakes on each corner of the wagon to hold the logs on.
(*: It took me a long time to figure out what they were called, so that I could order the bolster bracket that bolts to the bolster of my old running gear.)
I'll for sure will keep you posted guys, lot of information to think about here. Obviously not a lot of "grapple-log-trailer" here which confuses me a bit since i thought it was "the machine" i needed at the beginning. Need time to chew that.
Thanks
   / Winch, log trailer with grapple or both ?? #28
I can't speak for other posters here however a grappled trailer is way out of my logging budget. However, I don't log for money as it sounds like you are contemplating. Only you know your circumstances and if you feel your needing one, go for it.
   / Winch, log trailer with grapple or both ?? #29
Sounds like what I have been doing for the past twenty years.
When I was young and agile I used an electric 8000lb winch on the 3pth to bring them out to where a 20' chain would grab them, then forked them onto an old trailer (with bolsters)..a lot of climbing around.
Now I have a set of tire chains (4) on " John" and a helper with a chain saw and energy. We skid a lot more logs out to a landing than I ever did when I could walk....Ours is hilly hardwood bush.
Each year we burn 12 bush cord plus sell about two truck loads of basswood/poplar pulp....
What is your average skidding distance ? How many good size logs do you think a faily small kubota L3800 could safely skid at a time ?
Thanks
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2022 John Deere 1025R (A53317)
2022 John Deere...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
