Winch for 3 point
/ Winch for 3 point #1
Spikes
Rogers, Ar.
Kubota L3450
I have an old L3450 that sat for years. I got the engine going but the 3 point is dead. It was having major issues before the tractor was parked, so it’s going to be a bad piston / sleeve. The tractor has a ROPS and I was thinking about mounting an ATV winch to it to lift the blade or mower. I only use the tractor once or twice a year and I know fixing the 3 point is going to cost more than the machine is worth. Other than the obvious tight cable / flesh proximity, what says ye?
/ Winch for 3 point #2
A little bit "hillbilly" but I wouldn't talk you out of it.👍
Especially with infrequent use.
/ Winch for 3 point #3
What about putting on a hydraulic cylinder to do the lifting? Should be able to tap into the hydraulic circuit to add. Just another option.
/ Winch for 3 point
How would you mount the ram? Interesting idea!
/ Winch for 3 point #7
I've seen it done before, more than once, it works just fine. Double line it to slow it down...
I'm not convinced synthetic rope is safer though...
SR
/ Winch for 3 point #8
I'd make a bracket that would mount just below the top link with a bracket that would go down to one of the 3 point arms. Or if the lift arms move freely, you could make a bracket and push one of them up. A winch puts a lot of strain on a charging system. Most tractors don't have very high amp alternators to replace the winch draw.
/ Winch for 3 point #9
Why not troubleshoot and fix the 3 pt hitch? Could be expensive, could be cheap, no one knows without digging in a bit further. Most of the time, it's as simple as a remote lever being bumped into detent or a bad piston seal.
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
Farm Hand CG3000 Bale Grinder (A66408)
Farm Hand CG3000...
400 lb Electric Hoist (A66408)
400 lb Electric...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
