Will this end cap work?
   / Will this end cap work?
I know it's in the directional valve, but where is the relief valve? Seriously. I don't want to just start tearing it apart. (like I usually do :))
I believe it is a Cross brand valve, if that makes a difference. Have been looking online but cannot find a cut away or layout of that brand.
   / Will this end cap work? #13
Just search cross mfg.
OK so I found this, but the info below does not label anything.
Manuals-and-Options_Directional-Control-Valves-Technical-Service-Manual_Production-Drawing.jpg
From looking at the diagram, it would seem to me, the spring loaded valve on the end opposite the handle is the spring tension you feel when using the valve, and so the spring valve next to the handle must be the relief valve?
My next question is do I simply undo the nut that holds it together, to check and free up the relief valve? I fear if I turn it at all I may be adjusting it, and I have no pressure gauge to test with.
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
