Will The tank Empty?
/ Will The tank Empty? #1
Frankdozer
Bridgton, Maine
1967 Case 580CK Backhoe / Loader
When I disconnect the 2 hydraulic lines from the bucket cylinder to the control valve on my dozer, will the fluid drain from the tank or just what is in the lines? Or should I just drain out all the fluid then remove the lines? Thanks, Frank
/ Will The tank Empty? #2
When your valves are in neutral, the flow is blocked. What ever is in the hose/cyl might leak out.
/ Will The tank Empty? #3
If your valve is working correctly then all you should get out of the hose is jut the fluid in them. The fluid should remain in your tank.
So no need to drain the tank to take the hoses from the valve to the cylinder off.
Chad
/ Will The tank Empty? #4
make sure that the bucket and loader are well supported since gravity will force any fluid it can out of the lines as soon as you disconnect them. A full cylinder can hold a lot of oil that will shoot pretty hard with the weight of a bucket curling to push on it.
2022 EZ-GO ELITE...
2010 Cadillac CTS Sedan (A61574)
2010 Cadillac CTS...
1999 Sea Ray Boat w/ 2015 Shorelander T/A Boat Trailer (A61574)
1999 Sea Ray Boat...
John Deere 608C 6 Row Corn Head (A64119)
John Deere 608C 6...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
Deere 120 (A64119)
Deere 120 (A64119)
