Will the CK27 be "enough" tractor
   / Will the CK27 be "enough" tractor #51
When I first got my little Case 310 dozer, I only worked it in 1st gear, but with many hours on the machine I can now do many of the things that I use to only do in 1st gear in 2nd. Not only as good but better. Everything does not have to be done at a snails pace. That is not to say that there are times when you shouldn't work at a slower pace, just that you do not have to do all tasks slow to be able to do them well. ;)
Sorry, but your California soil is much lighter than the wet dense clay mixed with shale and rocks that is so common here. You soil looks like it's pretty easy digging to me: light, dry, and shale free.
Also, high and low range are much different on the gear vs HST for the CKs, with the HST having 3 ranges and the gear only two. In low range, fourth gear, speed is ~ 4 MPH on my tractor. I pull my box in 2nd or 3rd because it's fast enough. Sometimes I use 4th, but often that's too fast, not allowing me sufficient time to make fine adjustments as the terrain varies up and down.
   / Will the CK27 be "enough" tractor #52
I'll give you that. My JD 955 was a 2 range HST and I never used high gear. I was excited to get a 3 range HST with my CK30, but I'm finding I almost preferred the 2 range, it gave me the speed I wanted and the power I needed.
Here's a good example of the difference hp and weight make. The 955 was less than 2000 lbs + the FEL and 33hp. It could dig better with the tires than the FEL, in either range :laughing:
Nothing wrong with gear tractors or the CK25/27, but the OP originally asked about HST tractors, and with that in mind, I'd recommend the CK30/35 and say I'd buy the CK35HST if I could hit the reset button.
   / Will the CK27 be "enough" tractor #53
You are correct, our soil is pretty much a dream to work with. This puts different loads on a machine vs what it sounds like you have to work with.
You have made my point perfectly, everyone does not have your conditions and therefore why should one purchase to meet your conditions. ;)
   / Will the CK27 be "enough" tractor #54
Well, not quite. My 3215 pulls 2.8MPH in low range and 5.1MPH in mid range. Yes it will and does pull a full load of dirt up hill in mid range. I can't even imagine working in low range all the time. I only use low range when rototilling.
Again, the equipment that some of you have for YOUR conditions and capabilities is good for YOU. Everyone has somewhat different circumstances and what works GREAT for you does not in any way mean that it applies to everyone. ;)
Its interesting to see how low, your low range is, the DK40-50 with Ags or Inds top speed is 3.5mph or 25% faster. Our mid range is only a bit taller at 6 mph though.
Makes a bit of a difference when we are talking about how effective a tractor is in each range though.
From what I've found so far with the HST is that it will put down the full torque of the engine in the upper 1/3 of the tractors speed in each range. In low range the HST always produces more torque than traction at any speed, but in mid range and high I can blow the relief valve at low speeds without the engine really working, but once you get going the HST can load the engine to its maximum in each range. The first time I could actually see the exhaust on my tractor was out on the road in high, as I could actually make the tractor open up the injection pump for a sustained run.
So I might be able to pull the full box blade up a slope at 4mph in medium range but not at 0.5mph, I don't have a box blade yet so I'll have to see.
Most of my soil contains many fist size rocks, a few volley ball sized, a few less beach balls, and the odd VW. So doing anything in virgin ground is going to happen in low range anyways just to make sure the sudden stops don't break something. Maybe out on the driveway once I get a good layer of grade A gravel going, I'll move that in medium range.
   / Will the CK27 be "enough" tractor #55
Still miss the point: you can't compare low range on the HST to low range on the gear. They aren't the same. The gear travels faster in low range while giving maximum power. If you aren't in low range, you aren't getting maximum power.
I stick by my recommendation: HST get the 35. Otherwise, get the 27 in gear; it'll perform better than or equal to the 27/30 HSTs. If you have to have HST, get the 35. The CK35HST is an awesome rig.
   / Will the CK27 be "enough" tractor #56
I would add that anyone spending the kind of bucks needed for a CK35HST should stop for a moment and at least consider the next step to the DK lineup. There is a much bigger difference between the CK35 and the DK40se than there is between the CK27 or even the CK20 and CK35 in just about all ways except perhaps pure mowing.
   / Will the CK27 be "enough" tractor #57
That statement goes for anything. I want enough power to get the job done in a timely manor without having to rely on low range whether it is HST or gear. So if it takes a CK35HST in mid range to out perform a CK27 gear in low range, so be it. Yes it may not be as great a difference between gear and HST. Yes maybe the CK27 gear will out perform the
CK30HST. Who cares? If a person wants HST, then they are best off with the max HP in that frame size. Maybe the $$$$ is a factor in a decision, maybe not.
The way you guys talk, I should have bought a 5520 (55HP) instead of my 7520, (75HP) same tractor, just less hp. I could be doing all my chores in 1st or 2nd gear instead of 6th,7th or even 8th. ;)
I give up, you win. Lets have a :drink: and move on. :thumbsup:
   / Will the CK27 be "enough" tractor #58
Brian, max hp in HST IS my recommendation. And I bet my 4th gear low range is about as fast as mid range HST in the CKs at full peddle. BTW, do you own a CK? Have you used one for chores? All HSTs aren't the same.
   / Will the CK27 be "enough" tractor #59
No I do not own a Kioti. I looked at them and was going to purchase one from Wallace, but then decided that I wanted an HST and I was not comfortable with the CK treadle. Went with the Mahindra 3215HST and have been happy with it. By the way, the 3215 is rated at 32hp, but dynos out at 34hp. :thumbsup:
   / Will the CK27 be "enough" tractor #60
Its fun debating tractors though:laughing:
I think in your case where you seem to make miles of roads out of the desert, then extra hp is not wasted at all. In my case I think all the DK50 would do is maybe run a box blade fractionally faster, but probably not since the HST's have all the same settings and it seems in mid range at lower speeds its the HST that's the limiting factor, not the HP... The 50 would probably brush hog faster, but I don't have one and I'm not sure I'm getting one. I'm not planning on a snow blower either so maybe I'll never ever wish I had the extra ponies? Maybe if I sell the tractor but I can show perspective buyer the shop manual with all the specs and do a decent sales pitch that unless your using maximum pto hp alot, you won't miss the few hp difference.
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
