Front-End Loader will not raise
/ will not raise #1
keithw1962
richland texas
kubota l3410
I have a Kubota L3410 with a Koyker L150 loader. The loader will not raise unless you pull the lever to tilt (left) and pull down 1/2 way to raise. It will lower but without enough power to lift the front end. Tilt works fine. Any ideas? I have already replaced the control valve and it does the same thing. Changed the hydraulic fluid and filters and rebuilt the cylinders for the lift. Thanks.
/ will not raise #2
Sometimes it’s the easy things like hoses aren’t connected right or quick disconnect aren’t setted or fitting not tight letting air pass by
/ will not raise #3
One other person had this problem and determined that one of the lift cylinders had come apart so the piston was disconnected from the rod.
