will not go into foward gear
   / will not go into foward gear #1
bigbosee
I have a 2009 McCormick CT36 with manual transmission . all of a sudden it will not go into foward gear,reverse is fine but neutral is also reverse. Any
suggestions?
   / will not go into foward gear #2
suggestions?
Check the obvious. Is the parking brake released? Check the linkage. Reverse might be gear low enough to overcome the friction but forward gear will stall the engine.
Is it a shuttle shift?
well I found out a few items.There is a pin on the foward.neutral ,reverse
lever shaft that can break if too much thrusting on leaver.That means
she will not go in gear.Unfortunatly,that is not my problem.Mine is more serious and turned out to be internal in the transmission.Judging on my location I could have sent the tractor on a 180 mile one way ride to Northern Conn or 35 miles away to a New Holland /John Deer dealer.I choose the latter and it turns out that the Korean transmission in a
McCormick CT36 is identical with the New HollandBoomer transmission.Both are made in Korea. I am amazed what MUTTS these tractors are.McCormick
CT tractors are the same as LS tractors with changeable parts. Anyway I put
a claim in with Ebay against the seller in Oakboro,NC and I can only wait. I quess this is international construction at its best.
quick update,The tractor is still in shop awaiting parts(1 month), the final bill said to be 3,400.00 dollars . Ebay's buyers protection plan is going to cover 3,200.00 dollars leaving me with 200.00 to pay. Not bad for Ebay!
NEW Fork Extensions (A59000)
NEW Fork...
1974 John Deere 6030 Tractor (A56435)
1974 John Deere...
1985 FREIGHTLINER DUMP TRUCK (A58214)
1985 FREIGHTLINER...
V-HULL ALUMINUM BOAT (A52708)
V-HULL ALUMINUM...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
