will not go into foward gear
   / will not go into foward gear #1
bigbosee
I have a 2009 McCormick CT36 with manual transmission . all of a sudden it will not go into foward gear,reverse is fine but neutral is also reverse. Any
suggestions?
   / will not go into foward gear #2
suggestions?
Check the obvious. Is the parking brake released? Check the linkage. Reverse might be gear low enough to overcome the friction but forward gear will stall the engine.
Is it a shuttle shift?
well I found out a few items.There is a pin on the foward.neutral ,reverse
lever shaft that can break if too much thrusting on leaver.That means
she will not go in gear.Unfortunatly,that is not my problem.Mine is more serious and turned out to be internal in the transmission.Judging on my location I could have sent the tractor on a 180 mile one way ride to Northern Conn or 35 miles away to a New Holland /John Deer dealer.I choose the latter and it turns out that the Korean transmission in a
McCormick CT36 is identical with the New HollandBoomer transmission.Both are made in Korea. I am amazed what MUTTS these tractors are.McCormick
CT tractors are the same as LS tractors with changeable parts. Anyway I put
a claim in with Ebay against the seller in Oakboro,NC and I can only wait. I quess this is international construction at its best.
quick update,The tractor is still in shop awaiting parts(1 month), the final bill said to be 3,400.00 dollars . Ebay's buyers protection plan is going to cover 3,200.00 dollars leaving me with 200.00 to pay. Not bad for Ebay!
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2019 Deere 35G (A53317)
2019 Deere 35G...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2018 Toro Reel Master 5510-D Fairway Reel Commercial Mower (A56857)
2018 Toro Reel...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2015 GENIE S-60 MANLIFT (A58216)
2015 GENIE S-60...
