Will it work?
/ Will it work? #21
The loader can be made to operate correctly if it is built strong enough for your tractor with the correct valve or CC adapter plus altering mounting brackets.
/ Will it work?
The tractor has a 3/4" by 8" to 12" plate steel frame underneath it from the front to the back. Plenty to mount it to and no worries of hurting the tractor.
Now I know I do not have to spend more on hydraulic valves.
The last problem is where to tie into the hydraulic system. O-ring type treaded connection on the pump with steel lines going to the transmission where it looks like it was made as part of the transmission or pressed into a hole in the transmission.
I will have to go over it again when I can. I am thinking there are some plugged ports somewhere. It did originally have a fel and bh on it.
I may have to take it to a dealer and ask them if I can't figure it out.
/ Will it work? #23
Parts schematic picture shows how JD recommended attaching hyd's to tractor. If you desire I can list the necessary JD parts number for fittings as the fitting for pressure is unique.
/ Will it work?
Thanks for the schematic. I have to tell you, looking at the schematic, I am a little lost. I am guessing the right side of the schematic is a location on the transmission, because I do not recall that looking like any part of the pump. ( the tractor is currently 120 west of me) And, I do not understand why all the parts and fittings when I was thinking all I needed was a couple of hose tied in at the right place. Now I need your help more than ever.
/ Will it work?
I was just noticing you are only an hour away for me.
/ Will it work? #26
Yes I reside in the newest town in Texas no too far from Grand Prairie,Tx. Fitting(parts key 15) needs to be removed and a tee installed for pressure. The pressure control valve(parts key 3) is located on RH side of trans case by hyd filter.
/ Will it work?
Thanks I will see if I can make it work.
HEIL AIR CONDITION PACKAGE UNIT (A64281)
HEIL AIR CONDITION...
2008 New Holland T2420 (A62177)
2008 New Holland...
MAKITA FRAMING NAILER MODEL-AN923-1 (A64281)
MAKITA FRAMING...
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
GAS POWERED 6" AUGER & STAND UP 24" SHOP FAN (A64281)
GAS POWERED 6"...
