will it work
/ will it work #1
deldirt
I have been given a large cylinder and want to use it on a splitter attached to a skid steer given these specs do yall think it will work ?
36 "long (closed)
2 " dia. shaft
24" circumference case
Plan to power it from the 50 hp skid steer using using aux control already in place.
Also, there is an fitting on each end and a smaller one on the back end. Any idea what this one is for ?
Thanks from redneck who knows little about hydraulics.
/ will it work #2
If the seals are good, it should work.
Are you sure about the circumference?
What is the diameter of the cyl?
Show some pictures with ruler.
/ will it work #3
3rd smaller port could be a pilot line line for a built in load holding valve. Some cylinders have this when used where load holding is a safety concern and there can be no plumbing between the load hold valve and the cylinder.
24" circumference = 7.64 " diameter so would estimate around 7" bore cylinder
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2023 Case TV450B (A62177)
2023 Case TV450B...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2013 GMC (A62613)
2013 GMC (A62613)
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
