will it work
/ will it work #1
deldirt
I have been given a large cylinder and want to use it on a splitter attached to a skid steer given these specs do yall think it will work ?
36 "long (closed)
2 " dia. shaft
24" circumference case
Plan to power it from the 50 hp skid steer using using aux control already in place.
Also, there is an fitting on each end and a smaller one on the back end. Any idea what this one is for ?
Thanks from redneck who knows little about hydraulics.
/ will it work #2
If the seals are good, it should work.
Are you sure about the circumference?
What is the diameter of the cyl?
Show some pictures with ruler.
/ will it work #3
3rd smaller port could be a pilot line line for a built in load holding valve. Some cylinders have this when used where load holding is a safety concern and there can be no plumbing between the load hold valve and the cylinder.
24" circumference = 7.64 " diameter so would estimate around 7" bore cylinder
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
6' 3Pt Disk (A66285)
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
Peterbilt 379 with a CAT C13 (A63688)
Peterbilt 379 with...
IRanch High-End Tricycle (A64119)
IRanch High-End...
