will it take off?
/ will it take off? #302
Those tires spinning at infinite speed blew when the bearing grease coked heating up the hub. This would surely reult in airframe damage and fire. Now all that is left is a puddle of melted metals on a burning conveyor. Surely this residual will be placed inside another aircraft and flown to the lab for analysis. This is definet indication the plane can fly.
/ will it take off? #303
JimParker said:
And that's the problem with everyone's logic - and I mean both sides!
If the conveyor is capable of infinite speed, it can also produce infinite DRAG at the wheels. Since acceleration occurs only if Thrust is greater than Drag, then it follows that the plane will NOT fly IF the conveyor is capable of creating enough drag (by turning the wheels at well-above-takeoff speed - maybe 10X to 20X that speed?). All you pilots, engineers, and mathematicians out there should remember that formula - it's part of basic ground school If Thrust = Drag, acceleration is ZERO.
On the other hand, if the conveyor is NOT able to turn that fast, and cannot change it's speed instantaneously to counteract the thrust provided by the propeller, the plane will eventually fly, becuse thrust will exceed drag for at least brief moments. When Thrust is greater than Drag, acceleration occurs.
Real world? The plane can (and will) take off, because the "perfect" conveyor doesn't exist.
Theoretical world described in the problem as stated? The plane will not move (it's so stated in the problem definition), and therefore won't take off.
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
:D:D:D:D:D:D:D:D:D:D:D:D
/ will it take off? #304
RobS said:
Taking the theoretical even further...
The moving conveyor has friction with the air in contact with it. This will cause the air to move (boundary layer theory). As the conveyor speed increases so does the air speed and thickness of this layer of moving air. Eventually, the moving air will be thick (tall) enough to flow over the airplane wings. Even if this does not create flight, it will reduce the normal force on the landing gear which will provide a proportionate reduction in the drag force of the wheels on the conveyor. The reduction in drag will want to make the plane move faster but then there's that pesky infinite speed conveyor. It will move faster yet, creating even more airflow due to the boundary conditions. More airflow equals more lift. Eventually, the airflow will produce enough lift to balance the airplane just above the rapidly moving conveyor.
Thus we have flight at zero ground speed... theoretically.
Now right after I thank that guy you go and make my head hurt again! :)
/ will it take off? #305
I dont get why the conveyor is capable of infinate speed. The only way that can be true is if the plane travels infinately fast. In the original question it was stated that the conveyor "MATCHES" the planes speed. If the plane reaches takeoff speed at around 80kts, the plane is going 80 forward and the conveyor is going 80 backward to match it. How are you getting infinate out of that?
Can someone please explain to me how this could occure? One more thing, how can the wheels spin without the whole plane moving? What is motivating them to do that?
/ will it take off? #306
You could tie a real plane in place on a real moving conveyor belt, run the belt up to any speed, and the wheels would match it without the plane going anywhere. The wheels are not driven by the engine in any airplane I know of.
Our plane could be sitting on our conveyor facing into a headwind. If the engine runs fast enough, the plane can sit still while the wind blows. The conveyor will not move, but if the wind gets to blowing fast enough the plane will lift off the conveyor while not moving forward or rearward. If the engine quits, the plane settles back down and is then blown rearward by the wind. This would cause the conveyor to run forward and the plane's wheels would then be spinning backwards.
/ will it take off? #307
daTeacha said:
The problem doesn't state the plane has wheels. Since everything has gotten theoretical, what if it had very slippery skis, like a bush plane? Then the boundary layer over the conveyor would tend to lift the skis as conveyor speed increased.
Wheels? It never even said the plane had an engine :D
/ will it take off? #308
You are sure looking for the answer you want to hear. That plane is long gone:)
John
/ will it take off? #309
On stationary pavement the engine does drive the wheels. What else drives the wheels? Engine creats thrust and moves the plane forward driving the wheels. What you likely ment to state is the wheels don't drive the plane.
/ will it take off? #310
RobJ said:
Well crap....I guess I can have paper...or plastic. But I can't have both at the same time!!! :D
Sure you can.. how much beer did you buy to read the rest of this?:D
/ will it take off? #311
Maybe we have it all wrong....
If we decide the plane is paper, figure in the reynolds number and thrust from my arm movement, I am sure I will end up on my face very fast when standing on the rapidly accelerating conveyor. At first I was going to end up on my backside, but there would not be as much thrust if I had to throw the plane back over my shoulder...:D
/ will it take off? #312
This probelm has nothing to do with existing equipment. Most engineering problems I encountered in school weren't feasable. due to some set of assumptions listed in the problem, we solved them.
Just how much drag would a set of bearings exert spinning at 100 mph? Not much compared to the force created by the thrust of the engine making the plane travel at 50 mph. ( convayor left at 50 mph and plane right at 50 mph = wheels/bearing 100 mph.
/ will it take off? #313
As a model aircraft flyer for many years
We run plane's in a test stand or on a dead man holding the plane, from moving forward(same as on the conveyor) they dont take off standing still
The bottom line if there isn't air flow over the wing (not prop blast) it will not take take off
the air flow over the wing causes low presure over top of the wing which causes the lift .
tommu56
/ will it take off? #314
RobS said:
I think you've hit on the crux of this problem. It's intentionally vague enough that everyone gets caught up in the various assumptions that need to be made. Of course, that's also what makes it fun, like any good debate.
I'm going to assume the plane has run out of gas and the winds are calm...
Nope. There is a tanker that is capable of infinite speeds feeding it. Therefore it doesn't matter if the plane takes off (tanker keeps up) or remains stationary it will never run out of fuel.
You just threw the wind speed in to add more confusion :)
Harry K
/ will it take off? #315
tommu56
So while someone is holding the plane stationary and the engine is revved, doesn't it try to move forward? It doesn't matter if the plane is being held on the ground, in the air, or on a moving conveyor belt, it still has forward thrust. The props thrust still propels the plane until IT FLIES!!
/ will it take off? #316
Ok, heres a good one.
You are riding your bike on a treadmill. You stay in one place, stationary, because the force of the treadmill and the force of the tires counteract each other, one moves forward while the other moves backward at the same speed. Now you get the bright idea to strap a big electric fan to your back. What do you think is going to happen when you switch the fan on?
With the force of the bike tires and the force of the treadmill counteracting each other allowing you to stay stationary, then you add the external force of the fan pushing you forward, the forces acting on you are now unbalanced. You will move forward. If you had wings and moved forward fast enough, you would takeoff.
/ will it take off? #318
I thought this would be kinda fun...
A man is standing on a movable conveyor ( something like a treadmill). Just infront of the man is a urinal. To the mans right is an unlimited supply of cold beer. The man begins to drink the beer and eventually begins to walk towards the urinal. As the man moves the conveyor moves but in the opposite direction. The conveyor has a system that tracks the speed of the man and matches it exactly in the opposite direction.
the question is
Will the man pee his pants or not?
/ will it take off? #319
the question is
Not if he already has them around his ankles as he shuffles towards the urinal.
There a good mental picture to start the day.
/ will it take off? #320
I would like to add to this theory. If that someone holding the plane were to be the imaginary conveyor, if they started to run to simulate being the conveyor and match the speed of the plane, it would take off when it hit the speed at which liftoff occurred. Unless the imaginary conveyor is moving the atmosphere along with the runner then you still have the friction of the air which creates lift and the runner would have to be tested for drug use or for some of EGON's coffee.
Steve
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
65' Extension Cord Reel (A66408)
65' Extension Cord...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Homemade Utility Trailer (A62613)
Homemade Utility...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
