MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,282
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
JimParker said:And that's the problem with everyone's logic - and I mean both sides!
If the conveyor is capable of infinite speed, it can also produce infinite DRAG at the wheels. Since acceleration occurs only if Thrust is greater than Drag, then it follows that the plane will NOT fly IF the conveyor is capable of creating enough drag (by turning the wheels at well-above-takeoff speed - maybe 10X to 20X that speed?). All you pilots, engineers, and mathematicians out there should remember that formula - it's part of basic ground school If Thrust = Drag, acceleration is ZERO.
On the other hand, if the conveyor is NOT able to turn that fast, and cannot change it's speed instantaneously to counteract the thrust provided by the propeller, the plane will eventually fly, becuse thrust will exceed drag for at least brief moments. When Thrust is greater than Drag, acceleration occurs.
Real world? The plane can (and will) take off, because the "perfect" conveyor doesn't exist.
Theoretical world described in the problem as stated? The plane will not move (it's so stated in the problem definition), and therefore won't take off.
RobS said:Taking the theoretical even further...
The moving conveyor has friction with the air in contact with it. This will cause the air to move (boundary layer theory). As the conveyor speed increases so does the air speed and thickness of this layer of moving air. Eventually, the moving air will be thick (tall) enough to flow over the airplane wings. Even if this does not create flight, it will reduce the normal force on the landing gear which will provide a proportionate reduction in the drag force of the wheels on the conveyor. The reduction in drag will want to make the plane move faster but then there's that pesky infinite speed conveyor. It will move faster yet, creating even more airflow due to the boundary conditions. More airflow equals more lift. Eventually, the airflow will produce enough lift to balance the airplane just above the rapidly moving conveyor.
Thus we have flight at zero ground speed... theoretically.
I dont get why the conveyor is capable of infinate speed. The only way that can be true is if the plane travels infinately fast. In the original question it was stated that the conveyor "MATCHES" the planes speed. If the plane reaches takeoff speed at around 80kts, the plane is going 80 forward and the conveyor is going 80 backward to match it. How are you getting infinate out of that?MossRoad said:Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
daTeacha said:The problem doesn't state the plane has wheels. Since everything has gotten theoretical, what if it had very slippery skis, like a bush plane? Then the boundary layer over the conveyor would tend to lift the skis as conveyor speed increased.
You are sure looking for the answer you want to hear. That plane is long goneMossRoad said:Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
daTeacha said:You could tie a real plane in place on a real moving conveyor belt, run the belt up to any speed, and the wheels would match it without the plane going anywhere. The wheels are not driven by the engine in any airplane I know of.
On stationary pavement the engine does drive the wheels. What else drives the wheels? Engine creats thrust and moves the plane forward driving the wheels. What you likely ment to state is the wheels don't drive the plane.
RobJ said:Well crap....I guess I can have paper...or plastic. But I can't have both at the same time!!!![]()
RobS said:I think you've hit on the crux of this problem. It's intentionally vague enough that everyone gets caught up in the various assumptions that need to be made. Of course, that's also what makes it fun, like any good debate.
I'm going to assume the plane has run out of gas and the winds are calm...
tommu56 said:As a model aircraft flyer for many years
We run plane's in a test stand or on a dead man holding the plane, from moving forward(same as on the conveyor) they dont take off standing still
The bottom line if there isn't air flow over the wing (not prop blast) it will not take take off
the air flow over the wing causes low presure over top of the wing which causes the lift .
tommu56
broomjob said:I thought this would be kinda fun...
A man is standing on a movable conveyor ( something like a treadmill). Just infront of the man is a urinal. To the mans right is an unlimited supply of cold beer. The man begins to drink the beer and eventually begins to walk towards the urinal. As the man moves the conveyor moves but in the opposite direction. The conveyor has a system that tracks the speed of the man and matches it exactly in the opposite direction.
the question is
Will the man pee his pants or not?
rutwad said:So while someone is holding the plane stationary and the engine is revved, doesn't it try to move forward? It doesn't matter if the plane is being held on the ground, in the air, or on a moving conveyor belt, it still has forward thrust. The props thrust still propels the plane until IT FLIES!!
