will it take off?
/ will it take off? #282
BillyP said:
The original details were
"a plane is standing on a movable runway( something like a conveyor).as the plane moves (relative to what, the conveyor or the ground?) the conveyor moves (relative to the ground? Presumably so, but not stated.) but in the opposite direction.the conveyor has a system that tracks the speed of the plane (relative to the ground? or relative to the conveyor?) and matches it exactly in the opposite direction (relative to the ground? or relative to the plane?)"
The only fixed point I see in this scenario is the ground on both sides of the conveyor? (That is all that I can see, also. But nowhere does the original problem state that the speeds are measured relative to that fixed point.) Are/can you read something else into it?
Let's restate the problem with the assumptions explicit.
"a plane is standing on a movable runway( something like a conveyor).as the plane moves forward, relative to the ground, the conveyor moves relative to the ground, but in the opposite direction.the conveyor has a system that tracks the speed of the plane relative to the ground and matches it exactly in the opposite direction, also relative to the ground. In other words, at any point in time, the conveyor moves aft relative to the ground at the same speed the plane moves forward relative to the ground. The air is stationary relative to the ground."
With the added stipulations, it becomes obvious that a person standing beside and facing the moving runway with the plane pointed to the right will see the plane moving to the right at some speed, say 10 mph, and the conveyor moving to the left at 10 mph. The plane is moving at 20 mph relative to a point on the conveyer. This is identical to a person standing beside a road seeing a car moving to the right at 10 mph and another car moving to the left at 10 mph. The occupants of each car see the other car moving closer (or farther away) at a rate of 20 mph.
A person riding on the conveyor will see the ground moving at 10 mph. That is exactly like the occupant of a car moving at 10 mph seeing the road moving past at 10 mph. That observer on the conveyor will also see the plane moving at 20 mph. That is identical to a person standing on the highway watching a car move away from him/her at 20 mph.
So, is the plane's movement measured relative to a tree growing beside the conveyor, or is it relative to the surface of the conveyor belt? If it's relative to the tree, then the plane moves forward relative to the air and will fly. If it's movement is measured relative to a point on the conveyor, then the plane stands still relative to the tree and the plane doesn't fly.
Of course, in the latter case, the pilot has to be very precise with power settings so that only enough thrust is generated to overcome the rotary inertia of the wheels and the friction in the wheel bearings. In other words, to apply only that power needed to taxi forward at a speed relative to the conveyer that's equal to the speed of the conveyor relative to the tree.
In an inertial coordinate system, net forward thrust on the a/c will cause the a/c to accelerate, gain speed, and move forward, as viewed in that coordinate system.
So, define your terms and explicitly state your assumptions, and the "problem" becomes a non-problem.
/ will it take off? #284
From what I read into it, the plane is moving forward or will. In order for me to see the plane move forward. imagine me as a tree, innocent bystander, news reporter, Janusz Zurakowski or whatever but I'm standing still beside (not on) the conveyor. :confused:
/ will it take off? #285
The problem with the scenario of the plane moving forward relative to the conveyor but not the surrounding ground is that its impossible to initiate. Meaning, that the conveyor, by definition, instantly matches the planes speed. The plane starts out not moving at all, so the conveyor isnt moving either. Some force has to be applied to the plane for it to move, so you start the engine and run up the power.
The thrust is either going to make it move forward or its not, those are the only two choices.
If it does move forward, then the scenario above is void becuae the plane is moving and will take off..
If the plane does not move forward, the wheels can not be turning at all so the conveyor will not move at all because it only matches what the plane is doing, which is absolutely nothing, so the plane just sits still with its engine running full throttle and not moving anywhere. Does that make sense?
If the plane does not move forward, the conveyor does not move backward. If the plane does move forward, the conveyor does move backward.
/ will it take off? #286
Oh, Ray, there you go getting practical!:) I agree, as a practical matter, it would be extremely difficult to initiate and maintain that scenario. However, a mathmatical argument might be made supporting a "conveyor-centric" view of the situation. But I'm not going to do it.
First, I'm sure it would be deadly boring to anyone not fascinated with things mathmatical, and second, I'm not sure my proficiency in calculus has survived the years since I last exercised it. But, for the mathmatically inclined, if you allow stepwise changes in the state vector while the system remains in equilibrium and then take the limit as the step size approaches zero, you may find the velocity of the plane relative to the conveyor can increase while it's velocity relative to the ground remains zero. Or you may find a singularity that renders the scenario impossible.
In either case, the proof is left as an exercise for the student. I'm quite content with a "ground-centric" view of the system in which the airplane accelerates to liftoff speed, the tires self-destruct, the wheel bearings melt, and the plane flies merrily away into the sunset as the pilot wonders whether or not to use synthetic oil at the next oil-change.
/ will it take off? #287
Since you settled that!!!Real good. What about the landing? If the pilot tries to land on the conveyor will it move as soon as and be at the same speed as the plane on touch down.HEEHEE.
/ will it take off? #288
If so, I sure hope the no-fly boys can come up with a way to keep the pilot from flying through the windshield when the plane comes to an instantaneous stop. Seat belts and shoulder harnesses are good, but they aren't designed for g-loads that high.:rolleyes:
And if we assume the standard, single engine, tractor (Hey, back on topic!) propeller configuration, they need to figure out how to keep that pilot projectile from going through the propeller disk too.:)
/ will it take off? #289
At least we agree that the plane would take off.
Im not with you on the runaway conveyor thing though.
What I see is a conveyor that is limited to what the plane is doing and a plane that needs some sort of force to continue moving, it wants to stop moving because of friction and drag. Remove or limit the trust acting on the plane and it stops.
It would seem you are on the verge of inventing a machine that creats its own source of power. It should be a real money maker for you.
/ will it take off? #290
We seem to be a bit hung up on relatives.:D
Air flow over airfoils; is this the crux of the debate ??:confused: :confused: :eek:
/ will it take off? #291
RayH said:
The prop is also an airfoil. When its spinning, it is creating lift, not vertical lift but horizontal lift. If you have horizontal lift that overcomes the small bit of drag of the wheels spinning, the plane will move forward, thus creating vertical lift and off into the wild blue.
And that's the problem with everyone's logic - and I mean both sides!
If the conveyor is capable of infinite speed, it can also produce infinite DRAG at the wheels. Since acceleration occurs only if Thrust is greater than Drag, then it follows that the plane will NOT fly IF the conveyor is capable of creating enough drag (by turning the wheels at well-above-takeoff speed - maybe 10X to 20X that speed?). All you pilots, engineers, and mathematicians out there should remember that formula - it's part of basic ground school If Thrust = Drag, acceleration is ZERO.
On the other hand, if the conveyor is NOT able to turn that fast, and cannot change it's speed instantaneously to counteract the thrust provided by the propeller, the plane will eventually fly, becuse thrust will exceed drag for at least brief moments. When Thrust is greater than Drag, acceleration occurs.
Real world? The plane can (and will) take off, because the "perfect" conveyor doesn't exist.
Theoretical world described in the problem as stated? The plane will not move (it's so stated in the problem definition), and therefore won't take off.
/ will it take off? #292
TheKid said:
I’m no physicist, but I do know the plane can either move, or not move, but it can't do both of them at the same time. :eek:
Well crap....I guess I can have paper...or plastic. But I can't have both at the same time!!! :D
/ will it take off? #293
I think someone also needs to count how many different ways "conveyor" was spelled in this thread. Probably count me in for a couple. :):)
/ will it take off? #294
Taking the theoretical even further...
The moving conveyor has friction with the air in contact with it. This will cause the air to move (boundary layer theory). As the conveyor speed increases so does the air speed and thickness of this layer of moving air. Eventually, the moving air will be thick (tall) enough to flow over the airplane wings. Even if this does not create flight, it will reduce the normal force on the landing gear which will provide a proportionate reduction in the drag force of the wheels on the conveyor. The reduction in drag will want to make the plane move faster but then there's that pesky infinite speed conveyor. It will move faster yet, creating even more airflow due to the boundary conditions. More airflow equals more lift. Eventually, the airflow will produce enough lift to balance the airplane just above the rapidly moving conveyor.
Thus we have flight at zero ground speed... theoretically.
/ will it take off? #296
Farmwithjunk said:
It ran out of fuel some time ago. If this plane leaves the ground now it's only because of all the HOT AIR. ;)
Thanks for your contribution! Every little bit helps :p
/ will it take off? #297
The problem doesn't state the plane has wheels. Since everything has gotten theoretical, what if it had very slippery skis, like a bush plane? Then the boundary layer over the conveyor would tend to lift the skis as conveyor speed increased.
/ will it take off? #298
I'm with RobS. Boundary layer and Reynolds number is your friend. But seriously guys, ain't it time to do something else. Like, couldn't we argue who "sucks more with a box blade" for a while.
/ will it take off? #299
Why and how would the conveyor ever need to counteract the thrust of the engine. They are not connected in any way. The conveyor does not need to counteract the thrust from the prop and the prop does not need to overcome the conveyor, thats why there are wheels that spin freely and are designed to offer little resistance. This, I think, is where the whole problem is. Some people believe that the conveyor offers resistance to the plane moving forward when it doesnt, at least not enough to make a difference.
I think everyone agrees that if the plane moves forward, it can fly. Thats pretty basic. I just dont understand what the "NO FLY" people believe is holding the plane back. Someone please tell me what is keeping the plane from moving forward when the engine is run up.
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
Cattle Feeder (A65640)
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
2021 KOBOTA SVL97-2 SKID STEER (A65053)
2021 KOBOTA...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
