Will cutting brass with steel cause a spark?
   / Will cutting brass with steel cause a spark? #62
Safe and easy
1) connect to a BBQ and make sure its empty
2) unscrew the valve to remove it
3) rinse tank with water, dump, refill to overflowing, dump water and use now
That was my process. Chopped up an old propane can to make a forge.
Ratchet straped the tank to a trailer then used a big wrench to pull the valve. Fill with water to displace anything flammable. Cut it up with a grinder after it mostly dried off.
   / Will cutting brass with steel cause a spark? #63
I have some old propane tanks I would like to get rid of but they have to be opened. I am thinking of cutting the valve off with my Sawzall, but really don't care to blow myself up.
The valve is threaded into the tank. Righty tighty, lefty loosey…
Personally, I would make sure they are empty and without pressure first.
   / Will cutting brass with steel cause a spark? #64
I always filled them with water then cut the top off with a cutoff wheel .
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55314)
2012 Ford F-150...
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
Ford F450 Bucket Truck with Altec AT200A Boom (A57024)
Ford F450 Bucket...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
