Traction Will Ck2610 hst pull a 6' disc
   / Will Ck2610 hst pull a 6' disc #1
kittyhawk
Buffalo, Texas
JD X300 X350 Lawn Tractors. BRANSON 3620H
Hey everyone, I was wondering will a Ck2610 hst pull a 6' disc?
   / Will Ck2610 hst pull a 6' disc #2
Kioti CK2610 Dimensions
2016 -
Compact Utility tractor
Series: CK2510 ← CK2610 → CK3510
Dimensions
Wheelbase: 65.7 inches
166 cm
Length: 120.9 inches
307 cm
Width: 55.1 inches
139 cm (R1)
63.1 inches
160 cm (R4)
Height: 99.2 inches
251 cm
Gear Weight: 2646 lbs
1200 kg
Hydro Weight: 2701 lbs
1225 kg
Ground clearance: 13.4 inches
34 cm
Front tread: 44.6 inches
113 cm
Rear tread: 51.3 inches
130 cm
Engine Detail
Daedong 3A165LWM-U
diesel
3-cylinder
liquid-cooled inline
Displacement: 100.5 ci
1.6 L
Bore/Stroke: 3.425x3.638 inches
87 x 92 mm
Emissions: Tier IV
Power (gross): 24.5 hp
18.3 kW
Rated RPM: 2600
   / Will Ck2610 hst pull a 6' disc #3
Discs for compact tractor harrows come in 16"-18"-20"-22" diameter. Compact, 4-WD tractors with a bare weight of 2,700 pounds can handle 18" diameter notched discs. Tractors with bare weight of 3,500 pounds can handle heavier 20" discs; tractors with a bare weight of 4,500 pounds may opt for 22" discs. Weight is your friend.
A CK2610 can pull a Box Frame Tandem Disc harrow with 18" diameter pans, 60" wide, through moist soil under almost any scenario. You will need to run the tractor at full throttle in HST/MEDIUM in order to pull the disc with sufficient speed to mix soil.
A Box FrameTandem Disc Harrow with 18" diameter pans wider than 60" may stall the tractor during second and subsequent field passes when the moist soil had been softened by the first pass.
Disc pressure on the soil with 18" diameter pans is 35 pounds to 38 pounds per pan ~~ marginal for stirring soil not previously broken or not in good tilth.
CK2610 does not have enough tractor weight nor tractor power to functionally pull a Box Frame Tandem Disc Harrow with pans >18" in diameter.
You may be happier with a PTO powered 72" roto-tiller for mixing soil behind your CK2610, especially if the area you wish to till is less than five acres. The forward rotating tines of most roto-tillers push the tractor forward as the tines mix the soil.
T-B-N ARCHIVE: https://www.tractorbynet.com/forums...arrow-selection-compact.html?highlight=tandem
https://www.tractorbynet.com/forums...ree-point-hitch-mounted.html?highlight=tandem
   / Will Ck2610 hst pull a 6' disc #4
What are "18" diaper pans"?
   / Will Ck2610 hst pull a 6' disc #5
Depending on the soil and what you want to accomplish it may pull it in a fairly straight configuration. Proper angles and weight to do serious work will be a stretch.
   / Will Ck2610 hst pull a 6' disc #7
I pulled a 7' two-row disc with my 1.3L 23hp NH 1520 for nearly a dozen years, and with turf tires, so IMO yes!
That said, my JD 5210 2WD with draft control might struggle with the same tool if I let it run too deep in sand and would spin 13.6 x 28 R1s or bog. Seems its less about what you have and more about how you use it. :2cents:
   / Will Ck2610 hst pull a 6' disc #9
Video of larger disk breaking sod.
Several videos showing disks in use with results. There is a difference in results with a heavy disk and lots of horsepower.
   / Will Ck2610 hst pull a 6' disc #10
I've found that a chisel plow can break up small roots and require fewer passes after (stumping/digging) with the disc & before tilling, but still plenty of back & forth.
Some direction changes and at times a quick go-over with the LR before discing, and this isn't done to make food plots, its to open the path around the back of my ten, which gets overgrown with buckthorn & olive shoots. If things go well enough I can often skip the tiller, spread grass seed, and roll it in when clearing only 1/4 ac in a session.
I also scratch the path with disc to keep keep weeds down between mowing the cleared areas with the ZTR. Ya never know what a guy will do with a disc, but IMO having one is a must.
Thanks guys for all the Great information. What Im needing to do is repair Wild Hog Damage in my fields. The grounds already tore up so I just need to get back leveled out. Im about to buy a new compact tractor in the 25hp range and was checking on what size disc to look for.
   / Will Ck2610 hst pull a 6' disc #12
A six footer may need some weight on the front to keep the nose down.
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
