Will B2710 pull a 60" bush hog
/ Will B2710 pull a 60" bush hog #1
MarkLeininger
Platinum Member
Chicago suburban
Kubota 2710
Will B2710 pull a 60\" bush hog
I've got 5 acres of pasture, never let it grow out so I'm taking off at most 4-6" at a cutting. Will my B2710 pull a 60" bush hog through that? It's flat as a pancake here and the ground is reasonably smooth.
/ Will B2710 pull a 60" bush hog #2
Re: Will B2710 pull a 60\" bush hog
How many horsepower does a 2710 make?
If 4-6" of grassy growth and the machine makes 27 HP then as long as the tractor can pick it up it will cut the feld no problem.
I'll add that just because the hog is 60" wide doesn't mean you need to take 60" wide cuts. You can overlap three feet to make it a 2 foot cut. The first lap will be slower since it will be a full 60" cut.
As long as your machine can be hooked to the cutter you can get it done.
/ Will B2710 pull a 60" bush hog #3
I believe our new B7610 is a few hp smaller than your B2710. I went with a KK 60" with some hesitation, and the few hours I put on it last week went well. A little difficult going up terraces, but no problem in heavy grass on flat areas.
/ Will B2710 pull a 60" bush hog #4
Every year I help my buddy cut 5 acres of chest high weeds. He calls it pasture when there are horses around to keep it under control. There haven't been horses there for a while.
The 5' BushHog Squealer I use is powered by a 24hp JD 855. It has 19 hp at the PTO. The tractor is working a little bit to cut that tall grass and weeds, but I wouldn't choose to go with a smaller cutter. I don't think your 27hp will have any trouble.
OkieG
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Allis Chalmers WD45 (A66285)
Allis Chalmers...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
