Will a MMM be compatable with any loaders?
/ Will a MMM be compatable with any loaders? #1
Camo
Southwest Pennsylvania
I just bought a B5200 with MMM to mow with, and use with a FEL. Will I have to use a rear finish mower to be able to find a loader to fit my tractor???? I don't mind a quality aftermarket loader like a Woods or something...
/ Will a MMM be compatable with any loaders? #2
It will depend on the loader. Modifications may be needed!:confused: :confused: :confused:
I'm not even in the know of what brands are available besides Woods.:confused:
/ Will a MMM be compatable with any loaders? #4
Ansung, Buhler/Allied, Bush Hog, Great Bend, Servis-Rhino, Westendorf, Woods Equipment - just to name a few. You might want to find out what brands your local tractor dealers sell. Then contact the manufacturers to find out if they have a mounting kit for your tractor and if they do, whether the mounting kit is compatible with your MMM. The manufacturers could also give you information as to who their local dealer is.
There is a member here, Rback33, who could probably give you some pretty good guidance, if you PM him.
Good luck in your search.
/ Will a MMM be compatable with any loaders? #5
I can't specifically answer your question, but I own an L3130 with an MMM and a loader. You can mount both at the same time, but the mower clearance is minimal so I usually take it off if I have loader work to do. Also, the MMM is only compatible with turf tires on the L3130.
Why only MMM with turf tires on your model? Learning....:confused:
/ Will a MMM be compatable with any loaders? #7
Not being a "regular" here.....what in the heck is an MMM???:confused:
Mid Mount Mower
FEL is front end loader
BH is backhoe
I'm learning too!;)
/ Will a MMM be compatable with any loaders? #9
Does Kubota still sell the loader? That would be my first choice for compatability with the MMM
/ Will a MMM be compatable with any loaders? #10
I think the turf tire compatibility with the MMM is probably clearance between the tires and the deck. Another possibility is that the MMM is a finish mower and lug tires are not real easy on a plush lawn.
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
Ford Golden Jubilee (Model NAA) Tractor (A66285)
Ford Golden...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
2005 International School Bus (A64194)
2005 International...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
