will a b3030/la403 dig?
/ will a b3030/la403 dig? #1
strokerduster
texas
kubota b3030
wanted to widen a section of my springfed creek before rain fills it up again. lots of large rocks embeded but markham toothbar had no problem. about 3 hours work. gonna work on other side hopefully next weekend.
another. water to left is about 3 feet deep now and would probably ruin your day if you rolled into it...
partial pile of what i dug out....
/ will a b3030/la403 dig? #4
Looks like your B3030 will dig as good as my L3130 with R1 ag tires. About how long did it take you to move that amount of dirt?
I have been thinking about trading my L3130 for a B2630 or B3030 with R4 tires. I would like something a little lighter so I can put it on lawns with an aerator and spreader.
Curt
thats about 3 hours work this afternoon. really wasn't a problem. toothbar is a must........ /forums/images/graemlins/laugh.gif
/ will a b3030/la403 dig? #6
Thanks for the pics! Kinda gives me a good idea of the capabilities of my own setup..
/ will a b3030/la403 dig? #7
Nice work. It must be quite a spring if it feeds that creek. Looks like a lot of water, especially if it is 3 feet deep. It looks like you have the 60" bucket. Is that true or is it the 54".
tool, 54" bucket. i wanted the smaller one thinking it would dig better. spring has only been dry once since i bought property. i attempted to dig it out a little during that period. after about an hours digging, it started filling up with water again. normally cold and clear. my kids sometimes swim in it during summer when full but it's almost too cold even in july........ /forums/images/graemlins/smile.gif
round 2 on other side of the creek........ /forums/images/graemlins/laugh.gif
and another..........
and another...........
again.......
/ will a b3030/la403 dig? #13
It sure does dig. /forums/images/graemlins/cool.gif
But you are getting your tractor DIRTY. /forums/images/graemlins/crazy.gif/forums/images/graemlins/grin.gif
about 600 lbs. dead chevy 350 heads (free from machine shop) and 3 bags sackrete. 10.00 total expense.
/ will a b3030/la403 dig? #16
</font><font color="blue" class="small">( about 600 lbs. dead chevy 350 heads (free from machine shop) and 3 bags sackrete. 10.00 total expense. )</font>
Strokerduster, is the weight bucket held up using the 3 pt. hitch? Why I ask is that when I put my weight bucket on my Kubota B1550 I have chains attached to the lower links then they run up to the top link. I then lower the weight bucket down and let the chains take up the slack and hold ALL OF THE WEIGHT. I feel that this takes the pressure off of the hydraulic system. Does this make sense to you?
it was designed to carry much more than 600lbs on the 3 pt hitch so i don't worry about it. it's hydraulic pressure holding it and i let it all the way down when not in use. thats what the factory made the ballast box to do. i don't see a problem either way.................. /forums/images/graemlins/laugh.gif
/ will a b3030/la403 dig? #18
SRS, the hydraulic system is not constantly applying pressure to the 3pt arms when the handle in the neutral position. Pressure is only applied when you put the handle in the raise position.
Chaining it up only keeps the 3pt arms from bleeding down if you don't have position control.
/ will a b3030/la403 dig? #19
Strockerduster
Where did you get the step on the left side of the deck ?
John
oe kubota for b3030 cab model. cheap. have to remove when 72" mmm is on.
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
1995 NAVISTAR INTERNATIONAL 4700 S/A FUEL TRUCK (A65054)
1995 NAVISTAR...
PALLET OF LOAD JACKS W/ CASTER WHEELS (A64278)
PALLET OF LOAD...
