Widest wheel position on 4330
/ Widest wheel position on 4330 #1
nctacoma
Vermont
Kubota L4330
I need to adjust the spacing on my wheels for clearance for my new ice pick chains on my L4330.
It looks like I need to just jack up the tractor and swap the left side rim with the right side rim and I am done.
Is it that simple as just unbolting the hoops and swapping them?
I am guessing it will take a few hours but the chains are just slightly rubbing the fenders and that is no good.
Any advice? Can anyone show close-up pictures of their L series with the wheels in their widest setting?
/ Widest wheel position on 4330 #2
Does yours have the detachable center like this?
Yes it does. I am just finishing up.
It took me a few hours and a few creative solutions to lift up the tire after it fell over.
I ended up just swapping the right and left wheels and gained about 3-4". Now the tractor will be better in the woods and the chains won't rub anymore.
Any idea of the weight of a rim, tire, and chains, size 17.5x24? I know the aquiline chains are 150 each. The tire fell over and I couldn't even move it an inch to get it upright. I ended up using a come-along attached to the ceiling joists.
/ Widest wheel position on 4330 #4
My manual shows the different ways to flip the rims and place them on the centers for varying widths. I bought mine used and had my dealer extend mine out as I did enough of that when farming. We have another tractor with a FEL to use if we ever need to do anything with them and it sure makes it easier and safer. My brother also has an engine hoist if needed.
I don't have any idea what they weigh other than they are HEAVY.:laughing:
/ Widest wheel position on 4330 #5
When I did that same on filled 5030 tires I was very conscious that rolling upright and balanced involved no real weight, but every inch off-balance side to side seemed to increase in logarithmic fashion.
I jacked up the back end with the BH; used 6x6 PT blocks to assist keep stable, carefully rolled each tire to the rear, reversed direction, and then rolled forward to the other side.
Tedious and cautious.
/ Widest wheel position on 4330 #6
That's the way I did it when I was a LOT younger, but even then preferred a helper.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
Year: 2003 Make: International Model: 4300 Vehicle Type: Truck Mileage: 2,048 Plate: Body Type: T... (A61573)
Year: 2003 Make...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
