wider front tires
/ wider front tires #1
corelokt308win
I'd like to somehow rig wider front tires on my little Iseki TL2100 four wheel drive. The tires are always getting me stuck due to the loader weight. Are there wider rims with similar diameter, or could these be widened?
/ wider front tires #2
What ever you do match the tire diameter for the use. It is very imortant to match the tires as I've seen the drive shaft spitting out within four hours of operation! That's not cheap for any one!
/ wider front tires #3
What kind of weight do you have on the rear to offset what your picking up on the front? Might just need to load your rear tires or attach an implement, or both.
/ wider front tires #4
Always ensure you have adequate inflation in those front tires...that may be your problem.
And, maybe your fronts need replacing...might not have enough tread left on them.
/ wider front tires #5
/ wider front tires #6
I widened a pair of rims, not too hard to do. I put some pics up while I doing it on another forum
See here
/ wider front tires #7
Can you repost the pics here? It wouldn't let me see them without being a member/signing in or some such message.
/ wider front tires #8
You'll have to look at the other site for the descriptions of the pictures
/ wider front tires
The tires are new, 6 ply's. The rears are loaded with calcium in tubes. The fronts are sinking into a bog area that crosses most of my land. Once you go through the top most layer, it's pure mud about 4 feet deep. Wider fronts would help float the weight of the loader.
/ wider front tires #11
I took the 7.5" mud knives off the front of my 5005 Mahindra after the first winter. Luckily the 10" wheels off of my 4320 have the same lug pattern (I put 14" wide wheels on the 4320).
It really helped keep the front end up when putting out 5X6 rolls of hay in our typical wet East Texas winters. I would think just about any dealer would be able to lay hands on some wider wheels. But as mentioned before, double check the circumference of the new to make sure you end up w/ the same "gearing" for the 4WD.
/ wider front tires #12
Have you considered putting a 2nd set of wheels/tires on the front hubs? Since the wheels are a reverse type offset wheel, you ought to be able to mount a 2nd wheel on each front hub with some spacers and longer studs. Then you would have a dual tire configuration that would have better flotation. You can check this out using the other wheel on the axle to see how much stock it would take.
/ wider front tires #14
Get a spare set of rims that bolt up to your wheel. Cut the centers out of this set of wheels. Weld these centers into wider rims, being sure to have the right backspacing, before you weld. As mentioned before, do not change the rolling diameter of the tires that you are using, or you could cause mechanical drive line damage. Nothing against Milkman or Kubota, but that dually setup on the front looks to me like its going to break something. Just my 2 cents!:eek:
/ wider front tires #15
That Kubota front end does look pretty wide. Lots of leverage on that axle.
But if this is the machine in question:
you could probably get away with dual fronts.
Also curious, could the outside front tires be a smaller diameter? That way, during normal use the primary tires would be in use. When those start to sink in, the secondary tires would contact the ground. If the ground is soft enought for the secondary tires to touch down, there should also be enough slipage to prevent drive line binding.
Just some thoughts....
Doug
/ wider front tires #16
Doug, I don't know about everyone else but I kind of like the slightly smaller extra tires idea. The part of the extra tires farther away from the mount have greater leverage and wear the front wheel bearings more. If the tires were a tad smaler when on good solid surface you would not have the extra force, just when really needed.
Don't overdo the size differential as when the tread of the smaller tire engages softer ground it will have a smaller forward velocity than the larger tire which will tend to make for some slippage.
As far as whether or not that will effect the likelihood of lifting off from a "Magic Conveyor Belt", I don't want to take a stand, just yet.
Pat
/ wider front tires #17
Are the six bolt front rims the same size?
I wondering if I get a set off a Kubota MX5000 4wd will they work on my 2wd IH 424?
/ wider front tires #18
Only the weight that is mounted on the chassis behind the rear axle will reduce load on the front.
/ wider front tires #19
Loaded tires will prevent the rear comming off the ground (good). But wont unload the front axle (not good).
Think fat kid on a teter totter (loaderl. Do you want the 2nd fat kid sitting on the pivot in the middle (rear axle) or on the other end (3pt).
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
Frontier Root Grapple (A64126)
Frontier Root...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
