sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,855
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
My statement was made considering the use of full horsepower from an engine, and if you need just a little more horsepower, will it help to run WOT.
If your already running at max torque/horsepower, by the plotted curve, and you merely increase rpm, it doesn't help anything. However if your running an item that is rpm sensitive, such as a pump, an increase of rpm might help, provided the peak output of the pump hasn't been achieved. Since a loader is rpm sensitive due to the pump output, it doesn't apply to what I was thinking, wether or not I explained it that way.
Bottom line, the faster you throw heavy metal objects up and down, the harder it is on the bearings that absorb that force and the faster metal fatigue will affect it.
Probably won't make a difference to any of you WOT people, but that is my thoughts, and I'm sticking to running at less than WOT.
David from jax
David from jax
