Wicked TOOTH BAR for Tractor Buckets!!!!
   / Wicked TOOTH BAR for Tractor Buckets!!!! #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
A Wicked Toothbar has been on the back burner for wayyyy too long.
We've had many requests...well, basically customers begging us to put a Wicked spin on a tooth bar. You know, make the meanest, strongest, most premium and capable tooth bar on the Planet.
The time is now!!
* Custom built for buckets from 48" up to 72" wide.
* AR450 Steel Construction is VERY Strong, Durable, and Abrasion Resistant. This makes our tooth bar more durable and longer lasting than any other.
* Wicked, laser cut teeth are aggressively beveled and grooved for enhanced digging and ripping ability.
* Longer, more substantial "retaining hooks" hold the bar securely to the bucket, which promotes rigidity and bucket health.
* Easy installation only requires drilling two holes, but we also include lateral holes for carriage bolts if you prefer an even more permanent and secure install.
* USA Made in our North Carolina factory!
I'll add more pics and info as these enter full production. Seven guys from the Everything Attachments Channel Group are already in line!
Travis
   / Wicked TOOTH BAR for Tractor Buckets!!!! #2
Bravo! Can't wait to see it in action! :thumbsup:
   / Wicked TOOTH BAR for Tractor Buckets!!!! #3
Hummm looks a lot like another brand I know of.
   / Wicked TOOTH BAR for Tractor Buckets!!!! #4
I'm very curious as to the pricing on this item. EA has proven thus far that top notch American quality is the minimum for them doing business.
As for the person saying it looks similar to someone else's product, id say most single purpose items look alike. Bush hogs look like bush hogs, box blades look like box blades and tooth bars look like tooth bars. It's the quality of materials and manufacturing that sets anything apart from the other guy.
   / Wicked TOOTH BAR for Tractor Buckets!!!! #6
1) 66" BXpanded Piranha toothbar $319+30 s/h = $349
1) 66" Wicked Tooth Bar $435 free s/h
   / Wicked TOOTH BAR for Tractor Buckets!!!! #7
likewise ...preferably demonstrated in some hard/baked clay. :D
Old Ted will test it on concrete just to make sure LOL. I'll give him credit...his stuff is treated roughly and way out of spec to make sure it holds up.
   / Wicked TOOTH BAR for Tractor Buckets!!!! #8
Quality endures long after the price is forgotten.....
Check out the introductory prices here: EA Wicked Tooth Bar for Tractor Buckets
Thanks for the kind words. We are certainly dedicated to providing the best quality and customer service in the industry.
I think you nailed it. We certainly like turning things up a few notches when the opportunity is present.
Travis
I can more than justify the cost difference by showing you the added value in our Wicked Tooth Bar.
Material:
Wicked Tooth Bar = AR450 Steel has a yield strength of around 175,000 lbs minimum yield. That is 75% stronger than 100K steel, and 250% stronger than 50K steel.
Piranah = "very serious steel" according to their website. Just what is very serious steel?
Enhanced Design:
The laser cut grooves on the wider teeth will add to the digging and ripping ability.
The Wicked tooth bar goes through an additional, time consuming process after being cut by the laser. We put it in the mill and cut an aggressive 70 degree bevel to add to its digging and ripping ability.
Does it cost more to do all of this? Yes.
Is the higher cost worth the reward? Most definitely.
Travis
   / Wicked TOOTH BAR for Tractor Buckets!!!! #12
Material:
Enhanced Design:
Travis
Thank you for the detailed and visually supported write up Travis.
   / Wicked TOOTH BAR for Tractor Buckets!!!! #13
What are the weights of each size tooth bar? Might be worth noting, especially for a guy with a smaller machine who is more susceptible to extra weight
   / Wicked TOOTH BAR for Tractor Buckets!!!! #14
I see these can be custom made too....like to bolt to a Bobcat bucket....for consumer testing.....:dance1:
The bar has square holes in case someone wants to bolt it. You'd just need to make holes in your bucket.
We can also send the toothbar without the side mounting ears if requested.
Travis
I'll add weights when the various sizes start shipping. I'm guessing the 48" will be around 45 pounds, so it wouldn't hurt a small tractor's ability.
Travis
100% agreed. The screen shot below is from our homepage. Check out the last sentence.. :thumbsup:
Travis
   / Wicked TOOTH BAR for Tractor Buckets!!!! #19
"Material:
Piranha = "very serious steel" according to their website. Just what is very serious steel?"
thank you!
   / Wicked TOOTH BAR for Tractor Buckets!!!! #20
Just curious...Is there a copycat version of the "Ratchet Rake" in the works too?
2449 (A60432)
2449 (A60432)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
Club Car Utility Cart (A55851)
Club Car Utility...
