Why zero-turn mowers?
/ Why zero-turn mowers?
I guess like most other things, it comes down to priorities. It takes me about about 1.5 hours to cut my grass with my old 36" deck John Deere. And I can do it with one hand free. :) I guess I'd rather spend money on equipment that can do more than just fulfill an annoying obligation like cutting grass. But, I certainly don't fault anyone for having different opinions or priorities! I'm sure if I took a ZTR out and cut my grass, I'd like it a lot. I'd probably benefit a lot from it, since while it takes 1.5 hours to cut my grass, I don't have much grass to cut - just a lot of maneuvering around.
/ Why zero-turn mowers? #42
At BAR-BOB Ranch we have all four mower types: 22" push, 42' RIDE, 50" ZTR and 60" Bota powed Bush Hog. With 7+ acres to mow and over 550 trees to mow around the ZTR is the tool of choice. I believe it wins hands down for quality of cut, towing trailer, harrowing driveway, towing spreader, ease of use, ride comfort, work effort, time spent and ease of routine maintenance. Only the old push mower gets used anymore. ZTR does not handle two areas around the house where elevation changes rapidly. It scalps. Future "to do list" includes smoothing the slope so ZTR can be used eveywhere. PS wanna buy heavly used 42" rider and 60" Bush Hog?
/ Why zero-turn mowers? #43
At my work I have what I believe to be the worlds biggest zero-turn mower. It is an Excel Hustler 4600 with the range wings. Were talking a 72" out front mower with a 48" deck on either side. It cuts nearly 14 feet wide. It has a 38 HP Kubota diesel. You control everything with a single stick. Push it forward, twist it left or right, pull it back to stop or reverse.. It will do a complete 360 in it's own radius. It will go where your mind goes too. Best maneuverability of any machine out there and that is where a zero-turn shines. BUT, it takes a lot of practice and skill to keep it straight. The slightest twitch, sneeze, swat of a fly, or errant birdwatching will mess up a ballfield real quick. And the owners manual tells you to use one hand while driving it.
/ Why zero-turn mowers? #44
Came down to time, maneuverability AND comfort for me. I bought a ZTR with suspension (Ferris) this year and my back is thanking me. It cut my mowing time by more than half. If I really want a pretty cut then it takes a little longer but in general I just want to get it done so I can do other things.
I still use my riding mower for hills and my tractor for thick pasture and straight lines. It's nice to have the right tools.
/ Why zero-turn mowers? #45
Bought a new stand on ZTR to add to the existing machines in use for commerical needs. Tried it on my lot and decided it will never leave my lot - basically retiring my garden tractor for mowing duties. Not as comfortable as the ride on, but a heck of a lot faster and cut quality is supurb - thats all that matters for me
/ Why zero-turn mowers? #46
If you are considering a large garden tractor mower vs a ZTR, then get the ZTR. I almost bought a used JD 425 AWS instead my new, commercial ZTR. The new ZTR was a few hundred more. Glad I got the ZTR. I mow about 3 acres and around another 300 trees. The only problem is going around the trees so fast you may experience dizziness. ZTR's rock if the amount of mowing is large, lots of obstacles/trees and you want a finish cut with minimal yard damage. My wife uses it more than I do. She won't let me mow anymore. I do get to use it for fertilizing. I do get to sharpen the blades, change the oil, and put in the gas. :rolleyes:
/ Why zero-turn mowers? #48
Ray,
Unfortunately, I have not looked at the entire thread here, but I must say I am not 100% sure why so many buy ZTR's. I hear a lot, "cut my mowing time in half" or more and I do not doubt these claims. I can say my 757 ZTR definitely did NOT cut my mowing time in half, but I like it nonetheless. I believe ZTR's are the best mowing alternative for most of us out there, but not for all. Two years ago I bought a 757 for my dad as he has a lot to mow. I use the machine also, and like it. I do not like it any better than my X595 diesel garden tractor I used on his property before. The ZTR is faster, but as I have mentioned in previous postings, I cannot achieve more than a 15-20% difference here, and I am a decent operator. I believe a ZTR will lower one's mowing time substantially if one is going from a standard, milktoast lawn tractor, but not from something like a 595, which mows pretty fast. I am not saying I dislike the 757. It is fast and fun to operate, but it simply in my usage, is not that much faster than what I had before, and it can't pull a tiller.
John M
jcmseven said:
... it can't pull a tiller.
That's the another thing I wondered about that I forgot to mention. I have a few yard carts and things that I tow behind my little lawn tractor. I often cut the grass with a cart on the back, actually, so I can pick up tree debris as I'm cutting.
In addition to hauling hard carts, I've used my lawn tractor to move other tractors that weren't running at the time or other things that can be hooked up with a tow rope. My guess has always been that a zero-turn can't really (safely, at least) do these kinds of things. It just seemed to me that a zero-turn mower is just a very single-purpose machine - a grass cutter.
Also, it seems for what they cost, it'd actually be more effective to pay a landscaping guy to cut your grass every week! :D
/ Why zero-turn mowers? #51
There are those out there that time does not matter much to, but for me, a zero turn is a must. I mow professionally, and time is money. I got a 60 " Dixie chopper with the Kohler 28 hp EFI engine. This machine will do 15 mph at wide open throttle! Not that you could mow that fast, but it saves travel time at jobsites. An average 2 acre lawn with about 12 trees, well, and a couple of other obstacles can be cut in about 50 minutes! That includes weedwhacking!:D Reminds me of the old joke about the farmer who is holding his pig up to the apple tree, to eat the apples off the tree, when a city slicker asks him wouldn't it save time to shake the tree, and let the pig pick up the apples at his own pace? Farmer replied-
What's time to a pig?:D :D :D
For professional mowing, it makes perfect sense. I don't think that I'd try professionally mowing with my 36" deck chain-store John Deere. :D
/ Why zero-turn mowers? #53
I've been looking at ZTRs for the past several weeks. Salesmen tell me that time is the big factor. In fact I thought I should share what one saleseman told me. First he started by saying that they claim a 40% decrease in time. I responded that I had usually heard 50%.
Then he told me of a recent customer that went from 8 hours mowing with his old mower to less than 2 hours with the 60" ZTR. I was a bit amazed (can I also say doubtful) about that claim.
He then grinned and said, the guy went from a 20" push mower to a 60" ZTR. I guess if that is your case, you can expect to save lots of time.
/ Why zero-turn mowers? #54
Hi
I will also defend the old conventional way too. I have an Agco Allis 1614H, Agco Allis 1920H & John Deere 455 AWS. The 455 & 1614H are 12 years old. Sure they might not be brand new but they get the job done. I love my 455AWS the best, as you can really manuver around objects not to mention you can basically eliminate stoping to back up and the ends of the lawn, where you can just simply steer right back into it. Next year the 455 will be 13years old, but it is still a young tractor in my area compared to some mowers that are 20+ years old going strong. Know of several 317's, 420's & 430's going strong. Best thing about the 455 is the Yanmar Diesel! Plenty of power and it is amazing on fuel. I can cut grass that is up to 4 -5 inches in high and it you can't tell that the engine is being worked. Very impressed. I heard other 455 owners say the same thing, had to try it for myself. I also cut grass commerically and have found the 455 AWS to be very productive and notice a big improvement over the 2WS Agco's. I have driven Zero turns as well, and while they really cut grass fast, I have never been impressed with the quality of cut. I know my customers really like a great cut and they have been very impressed with the quality of the job that my 455 does. My 455 may be 12 years old, but with proper maintence and TLC that Yanmar should be purring past the 20 year mark. If the 430 Diesel Garden tractors can reach 20+ years then a well taken care of 455 should be able to do the same. I am looking forward to the many years of work ahead with my 455. I also found the 455 to be more stable on hillsides and I feel more comfortable driving a tractor then a zero turn, which is another reason why I won't switch to a Zero turn. Take Care Jason B
/ Why zero-turn mowers? #55
In my previous house we had about 2 acres - but on a significant hill. Using my push mower was out of the question (I did try), so I bought a JD L110 42" riding mower. Great Machine. Not only did the mowing time get cut from over a period of several days to about 2 hours, but I could do the whole yard drinking a Dr Pepper having a ball.
But last Summer we moved to a house in town with 7.5 acres (almost all has to be mowed), so on the recommendation of my son in law I bought an Exmark. This yard would be impossible with the JD L110, I would be permanantly on the L110. I can do it in about 6 hrs on the Exmark over 3 days. The Exmark is amazing - extremely fast and essentially eliminates trimming.
My most recent addition to my motorized stable is my beloved JD 790 tractor. I really am enjoying it and this past Friday I bought my first implements (5' box blade and a spreader). I will probably continue to mow the yard with the Exmark because a finishing mower attachment cost $$$$, and the JD would probably not be as fast as the Exmark ZTR.
My 2 cents.
/ Why zero-turn mowers? #56
I had a one acre yard that had some wide open space and some spaces that were tight to maneuver. I bought a 42" ZTR and was able to mow spaces that I used to have to mow with a walk-behind. I had a Honda tractor that had a 46" cut but the maneuverability in small areas was not good I would spend so much time turning and shifting I could do it faster with the walk behind. When I got the Ztr the time was reduced to half. If you have wide open spaces or have no problem with the time spent, then a ZTR which are expensive, are a bad investment. In my case, I had small spaces and many trees. The trees are very easy to mow around with a ZTR. One problem I found with the ZTR is if your turf is not good and thick and you stop one wheel and spin the mower around, the tire that is not turning but is pivoting, will tear the grass. ZTRs are great machines and I would not be without one, but the traditional ways work well too. Morpheus
/ Why zero-turn mowers? #57
This is not a shortcoming of the machine, but an operator technique issue. What people tend to do with HST front deck "tiller steer" machines, like my own F620, is "lock" the inside wheel when making a "zero turn".
Don't do this. What you actually need to do is reverse the inside tire while doing a tight turn, instead of holding it "braked" by the steering lever. This way you don't rip the grass. Think of pivoting on the centerline of the machine and you realize that the inside wheel needs to turn backwards.
Of course, it is best to avoid making these kinds of turns unless absolutely necessary.
Not all "ZTRs" are equal.
I guess everyone is assuming that when the OP means "ZTR" he means the front deck HSTs that you steer with levers that apply differential power/braking to the drive wheels. My BIL's Steiner with 72" front deck would be considered a zero turn machine, but has a steering wheel that turns the rear wheels. He can't apply torque to either drive wheel as needed like I can with my F620 in slippery conditions.
Also there are garden tractors with belly mowers and 4 wheel steer that I guess could be called ZTR. Never tried one of these, but the main reason I save so much time with the F620 over what I used previously is the ability to "sweep" the offset front deck under the spruce/pine/fir trees without damaging them or getting to cosy to the prickly bits.
The previous machine was a National 68" triplex gang reel mower, which cut wider and did a nice job, but couldn't cut in reverse, left dandelions standing, or it would gag on pine cones.
The only down side I can think of with HST tiller steer machines is it takes concentration to drive in a straight line, although I can drive it with one hand.
To answer the OP's question, it isn't so much the fact that you can turn the machine in its own length, an "almost zero-turn" would work for me, but it is more the quality of cut which is dictated more IMO by the deck design than anything else.
Some posters argue that they don't put a priority on saving time but enjoy the time spent sitting on their garden tractor cutting grass.
I enjoy the time spent as well, but what I don't like is wasting time and gas having to maneuver a cumbersome machine that requires a lot of driving over already cut areas just to turn around.
The overall time saved is variable depending on the condition of the terrain. I can't drive the F620 any faster than anything else on some parts of the yard due to lumpy ground. Where the smooth areas are though, I can really fly.
/ Why zero-turn mowers? #58
Useful thread but any chance of posting some pics of some of the machines mentioned here? They might help me make a choice about which machine.
I've been trying to manage our lawn areas (a couple of acres, some of it kinda rough) with my L3130 Kub with a 72" rfm. The Kubota rear tires are water filled to counterbalance for the front loader and I really need the loader for year round jobs so can't remove it and drain the tires. If the lawn is even a little wet, or if I take anything but very broad sweeping turns (with Ag tires), I dig ruts. I hate the thought of parking a rfm only a couple seasons old but I've no choice. I need to migrate to a machine that can do the job fast and neat and not leave tire tracks that have to be sand filled in places.
/ Why zero-turn mowers? #59
ccsial said:
I have a freind that would disagree with this. He tried it and could not get traction up the grades.
Sorry I didn't see this for a long time! Think of it this way, a garden tractor is front engine, a zero turn is rear so you already have more weight over the drive wheels. A garden tractor has an open differential and if you are very lucky, a diff lock or turning brakes, but if not, you have one wheel drive. A zero turn has two wheel motors so good traction to BOTH rear wheels.
The simple math adds up that a zero turn should plow better than a garden tractor.
On the Dixie Chopper with the Turf Boss tires, I suggest switching the tires from side to side for the winter for better bite and filling them with washer fluid for better weight.
One of the dealers near me has been plowing his driveway with a Coatesville Classic for years and he tells me he cut the time it takes him in half and that is compared to an old school cast iron garden tractor that had wheel weights AND chains. Nothing on the Dixie but fluid in the tires!
Ken
/ Why zero-turn mowers? #60
You need to look at the towing specs, that's all. There a lot of brands out there not rated to tow much and I wouldn't hook anything up to the box store zero turns. The Dixie Choppers that I sell can all tow pretty good. The standard two pump units like the Silver Eagle can tow 1,000lbs and any of the quad loop mowers from the Coatesville Classic up are rated at 2,000lbs.
Ken
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
PATRIOT SINGLE AXLE CATTLE FEEDER W/CREEP RACK (A63291)
PATRIOT SINGLE...
Caterpillar Articulated Truck Parts and Service Manuals (A63117)
Caterpillar...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2004 INTERNATIONAL RA027 4X2 S/A DAY CAB TRACTOR (A59911)
2004 INTERNATIONAL...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
