SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,630
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I saw a front diff lock on one of the bigger Kiotis. I wish I had that option on my 7520. :licking:The front differential never locks, there is no lock mechanism on our CUT size tractors. there is no center differential on most of our CUTS either (some do have, but not many) On Hard surfaces (asphalt, or concrete) when making turns there can be binding (torque windup) between the front and rear. This results in tire wear, for sure and some extra strain on the front differential. But the danger of going down a steep hill in 2WD with a load in the bucket is very real, even on pavement if it has some loose gravel on it, the rear tires can and will break traction, resulting in a runaway if the hill is steep enough, and there is enough gravel, or going down a grassy slope, or anything that reduces traction. Having a heavy ballast on the back will help prevent this, but don't count on it. 4WD is your friend to prevent this. Been there and done that and have survived. What ever the heck you do, drop the bucket, drop the ballast, keep the steering wheel straight, don't swerve or you will surely overturn. Several guys on here can testify what happens when you swerve to miss something.
James K0UA
larry
