Why not sugar water in tires instead of beet juice?
   / Why not sugar water in tires instead of beet juice? #21
We use water and anti freeze.
   / Why not sugar water in tires instead of beet juice? #22
And at over $60 gallon would be pretty expensive ballast.
I've been paying $20 per guart.
   / Why not sugar water in tires instead of beet juice? #23
I sell for $10 a quart. But it would be a shame to waste it in a tire.
So, because of where I live, just north of Seattle, I will be seriously investigating the use of sugar water as ballast because the freezing hazard is low. We only get into the teens rarely and then not for long. Sugar doesn't provide the same freeze protection as other substances but I don't need protection from really cold temperatures. I already have wheel weights on the rears and they add about 70 lbs. per tire. My Yanmar manual says to use 273 lbs. of calcium chloride solution in each tire. So I need about 200 lbs. of liquid ballast weight. Somewhere there is a chart that shows how much volume a particular tire will hold and how much liquid ballast to add so that the tire is filled the proper amount. Using that chart I can figure out how much sugar I need to use. I may need to add some anti-freeze too and I don't know how that will affect the solubility of sugar in the water. In any case I will figure it out and then post the results here. Today I was offered the use of a pump that works for pumping liquid into tires so that's a bonus.
Eric
   / Why not sugar water in tires instead of beet juice? #26
Thanks. I saw that thread and skipped it so, I was totally in the dark.
Me too, but I just found it (or one if there are several?) and added something different to it.
   / Why not sugar water in tires instead of beet juice? #27
Does anyone here know the result of driving on tires with ice inside?
I bought an Oliver tractor with 38" tires at an auction years ago. It worked great but had been used for tractor pulls and the rear tires were unknowingly filled with water. When they froze I drove about 100 yards and the tubes got pulverized by the ice frozen solid inside the tires and the tractor returned to the yard with the tires flat on one position only. With every revolution of the tires there was a deep blip when the tractor flopped down like driving over a stump.
Water might be OK for tire ballast in the Caribbean but not in Canada.
   / Why not sugar water in tires instead of beet juice? #28
In the midwest, most of the sugar you buy is actually made from beets and not sugarcane so you would be using the same stuff.
   / Why not sugar water in tires instead of beet juice? #29
Maple Syrup doesn't freeze, just gets thicker and it weighs 11 pounds per gallon.
It is environmentally friendly too!!😆
I would be having a waffle iron on my open cab tractor with an inverter. Not sure how the dust and grass clippings would go along with it.
   / Why not sugar water in tires instead of beet juice? #30
My dealer filled my tires with a new product named bio-ballast made of corn. He said it’s far less messy than beet juice, cheaper, and non toxic. I don’t know what it costs; it was wrapped into the deal.
I’ve used RV antifreeze. Safe for house plumbing, so don’t see any reason it would damage tires and wheels. Works to -20 F. Around $2-$2.50 a gallon
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2022 Wacker Neuson LTV6 Towable Light Tower (A56857)
2022 Wacker Neuson...
UNUSED FUTURE XKH39 39" HYD MINI HYD 4IN1 BUCKET (A58376)
UNUSED FUTURE...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2019 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2019 ALLMAND LIGHT...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
